two battery's should i?
Old Mar 29, 2014 | 02:27 PM
blueovelboy's Avatar
blueovelboy
ok so I just bought a travel trailer and it seems to run the icebox on 12V or 110v, the gas setting is not working at this time. so I ask if I should run two battery's so I can keep my frig cold going down the road or if you think my alternator will keep up with my frig, trailer battery, and truck battery or should I look in to a two battery system? I think its a upgrade that might help. but I know nothing about doing it or if it will upgrade my alternator to or not! so if you run two let me know how you did it or if you use it to its fullest!
thanks for any input
Jay
Old Mar 29, 2014 | 03:49 PM
cartmanea's Avatar
cartmanea
If your alternator doesn't keep it, it doesn't matter how many batteries you have.
Old Mar 29, 2014 | 04:02 PM
seventyseven250's Avatar
seventyseven250
Yep. Two batteries may help you when you are stopped, but if your alternator can't keep up, it'll just mean you arrive at your destination with flat batteries.
How tough would it be to fix the gas setting? That's worked great for me on my rigs, and keeps the fridge cold as ice while driving.
Old Mar 29, 2014 | 08:01 PM
gunnarGSD's Avatar
gunnarGSD
The system was not designed to "charge" the trailer battery like a regular charger. Yes a trickle charge does go to the trailer battery but is was certainly not designed to run appliances on the unit. By the time you add up the cost of a battery and wire it all in, you might as well fix the gas problem on the trailer.
Old Mar 29, 2014 | 11:14 PM
PrinceValium's Avatar
PrinceValium
Your batteries should charge form the 7 pin connector...and honestly they only time that will not happen is if your alternator is weak. It is a good idea to have some batteries for your trailer and also maybe look into a solar panel for charging them when you are parked.
I would start with at least two deep cycle batteries.
Old Mar 30, 2014 | 12:36 PM
MZEMS2's Avatar
MZEMS2
Are you sure the fridge uses the truck battery at all? Ours was setup to only use the battery on the trailer, if it ever came to that. I would look into getting THAT issue fixed before I spent too much time or money on the second battery idea. It might just be something cheap and easy on the trailer like a relay or fuse.
Old Apr 2, 2014 | 08:49 AM
blueovelboy
thanks all the frig will be need to be replaced after I looked in to it a bit more its shot. now I get to buy a $2480.00 dollar frig for my trailer that's only going to get used 4 or 5 weeks a year! man that blows but thanks all for the help and replies.
Old Apr 2, 2014 | 06:15 PM
jyarosz's Avatar
jyarosz
A lot of people replace there rv fridges with home fridges that run on 110 volts.Then add a small invertor and a couple of batteries.The new fridges are very efficient and don,t use much power. Go to rv.net and read about it.
Old Apr 2, 2014 | 06:34 PM
bigdaddyII's Avatar
bigdaddyII
Couldnt you just ice down what you will be taking until you get to the campsite and can plug into 110v?
Old Apr 2, 2014 | 06:35 PM
cartmanea's Avatar
cartmanea
I've never actually camped at a campsite. Where we go, there's no 110V.
Old Apr 5, 2014 | 02:11 PM
Horse Doctor's Avatar
Horse Doctor
Most RV refrigerators operate on propane as well as 120 Volts and sometimes 12 volts. We run on propane all the time when on the road.
Old Apr 5, 2014 | 02:28 PM
MisterCMK's Avatar
MisterCMK
I never use the fridge in my camper on propane. I switch it to 12v while driving and use 120 when camping.
There is no need to have extra batteries for the refer. Just don't open it when it is on 12v and it will stay cold enough.
Sent from my Telegraph using IB AutoGroup
Old Apr 7, 2014 | 12:47 AM
blueovelboy
I dry camp (no water/power/sewage) a more than I do with hook ups
thanks ill look in to that
mine dose not have 12v anymore I found out with about $150 worth of spoiled food from this week end
Old Apr 7, 2014 | 12:19 PM
Torklift Sheryl's Avatar
Torklift Sheryl
SPONSOR
I just want to throw an idea out here because it looks like there could have been issues with the alternator and the fridge itself. If you are thinking about taking extra batteries with you as a back up, you might consider how they are protected because battery theft is popular these days unfortunately.
We have two battery security products available. The Hidden Power is a battery mount that attaches to the truck frame and trickle charges from the main battery but that sounds like you might run into some issues there due to the concerns with the alternator. Another idea is the Power Armor, it is a lockable diamond plate battery box that holds up to five spare batteries that can be mounted to the trailer tongue or bumper.
Take care and happy camping,
- Torklift Jen
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old Apr 7, 2014 | 02:18 PM
thomabb's Avatar
thomabb
I've got four 6-volt batteries, three solar panels, and an inverter. I never use the gas side of the fridge.
On the previous camper, we pulled the gas fridge an put a 10 cubic foot electric one in. We left it closed for a couple hours before we pulled out. Everything would stay cold. Our one experience camping without electric, we had a small generator we ran a couple hours a day to keep everything cold and charged up (no solar panels on that rig). That fridge is the only thing I miss about that old camper! Those dual mode fridges loose a lot of space to the absorption coils!
