97 power issue
Old Mar 29, 2014 | 10:56 AM
srpservices's Avatar
srpservices
97 power issue
i have a 97 f250 with an auto trans in it. I was pulling my snowmobile trailer and the lock up converter kept unlocking then would lock back up. I hooked a switch up along the side of the road to lock the converter in. with it locked in it was like I had no power. looked up on here on my phone what it was doing to get help and one thing I found was check speed sensor. crawled under n unplugged it cleaned it up some plugged it back in and away I went, worked for the rest of the 200 miles home. went and bought a new speed sensor n changed it, removed my switch for lock up and I have no power. put the pedal to the floor and I just wont zip rite up to speed. shifts up kinda hard and down shifts early and a little hard too. changed the throttle switch cause sometimes you could push the pedal and It wouldn't do any thing.
looking for some other things to try or look at.
thanks scott
Old Mar 29, 2014 | 09:08 PM
srpservices
the codes I get are P0107 BARO circuit low input. don't know what to do for that.
the other is a P0113 IAT sensor circuit high input
does anyone know where to find the BARO circuit at.
Old Mar 29, 2014 | 09:15 PM
oldbird1965's Avatar
oldbird1965
Well, I could make a guess but then our auto expert Mark will come on and make me look like the fool I am and then not tell me why I was wrong. So, my suggestion is to change the title of your thread to '97 auto issue' and Mark might show up. He really is an expert, just doesn't have any bed side manners! LOL
Old Mar 29, 2014 | 09:58 PM
srpservices
thanks for the reply Glen. I don't think it is a trans issue, I think it is motor.
I can put It to the floor and it will only go like 45 or 50.
unplugged the speed sensor n plugged it back in and it took off and shifted good. replaced sensor thinking that would do it but it doesn't seem to be the problem.
going to play with it some more tmw.
Old Mar 29, 2014 | 10:24 PM
oldbird1965
I see that now. The BARO is under the dash, somewhere up above the right knee. I never did find it. The IAT (intake air temperature) is by the air filter, I don't know why its reading high??
Old Mar 30, 2014 | 09:29 AM
Hussler's Avatar
Hussler
IAT - someone probably removed it, do you have an aftermarket air filter. It won't affect anything such as your symptoms.
BARO - like Glenn indicated under the dash, three wire connector. Sounds like its bad. I've read on here a bad BARO will cause poor engine performance and transmission shifts. IMO fix that first.
Old Mar 30, 2014 | 10:04 AM
srpservices
I do have a 6637 on there, I figured that was causing the one code.
I have a parts truck I will see if I can find the BARO sensor and swap them.
I did figure out how to ask the search question a little better and did get a lot of useful info. going to check fuel pressure too. filter again too.
thanks jim
Old Mar 30, 2014 | 10:56 AM
oldbird1965
If you do find the BARO, take a picture of it. If you want to replace it with a new one, I have a link where you can get one someplace.
Old Mar 30, 2014 | 02:34 PM
srpservices
well I think I found the Baro. does it look like this?
here you go glen
Old Mar 30, 2014 | 02:37 PM
srpservices
got a another truck and pulled the baro out of that and plugged it in and took it for a test run. truck ran great. shifted good and the lock up worked too.
hope this does it.
thanks for all the help.
Old Mar 30, 2014 | 02:45 PM
Hussler's Avatar
Hussler
hope this does it.
That's it ... good job and thanks for reporting back
Old Mar 30, 2014 | 07:34 PM
oldbird1965
Thanks srp, glad you got it going. I've been reading on here ten years and the BARO isn't discussed very often.
Furr308
Jan 3, 2016 04:43 PM
madMatador78
1983 - 2012 Ranger & B-Series
13
Mar 6, 2014 11:01 AM
Sirtopemshat
Dec 11, 2010 07:20 PM
viperrtblck
32
Jun 12, 2010 11:09 PM
