Fuel delivery issue...
Old May 20, 2014 | 09:19 PM
roughridn_sob's Avatar
roughridn_sob
JRS I don't think that could be done you'd have to break open the actual pump itself and I dunno if that'd be worth the time, effort and parts just to re-install and find out you didn't fix a damn thing or messed it up worse than it was.
Old May 21, 2014 | 09:21 PM
JRS2's Avatar
JRS2
Ok, here is a slightly different question. Are all the items shown in the pic inside the plastic housing which includes the fuel pump ? If so, some of the units not that expensive starting at around 40 it appears .....
Old May 22, 2014 | 06:52 AM
subford's Avatar
subford
Yes they are.
Old Jun 18, 2014 | 06:18 PM
roughridn_sob
So I am bumping this because I never actually tested that replacing the fuel pump fixed my cross fueling issue I just assumed it would. I dont use the rear tank the often but I figured this week when I filled up i would use the rear tank just to make sure everything was still working. Low and behold I am still expierienceing cross fueling issue.
Is the FDM witht he shuttle valve part of the pump or does it interact with the sending unit. What I did before was ditch the old pump but reuse the sending unit on the front tank. I find it highly unlikely that I recieved a brand new pump with a faulty FDM.....guidance please!
Old Jun 18, 2014 | 07:02 PM
subford's Avatar
subford
No the shuttle valve is not part of the pump. It is a valve inside the FDM.
The pressure from the pump does open the shuttle valve in the FDM.
The sending unit just controls the fuel gauge and has nothing to do with the flow or pumping of the fuel.
The fuel pump:
The parts inside of the FDM:
Also look at the diagram in post #12 above in this thread.
Old Jun 18, 2014 | 07:08 PM
subford's Avatar
subford
It sounds like you still have a problem with the front FDM.
Why did you change the rear one?
Old Jun 18, 2014 | 07:18 PM
roughridn_sob
I didnt change the rear i changed the front pulled the fuel level sender off and re attached to the new pump.
Old Jun 18, 2014 | 07:45 PM
subford's Avatar
subford
Then if the front one is filling from the rear take the front FDM back and get another one and tell them it is bad.
Also try to get a different brand as I did hear that one manufacturer did leave the shuttle valve out of some and maybe you got one of those.
Miranda93
Jan 20, 2025 05:07 PM
torquemeister
Mar 29, 2019 10:15 PM
Joe097
Jan 30, 2016 08:59 AM
genesis850
Sep 15, 2015 01:29 PM
14&Ford
Nov 13, 2013 09:50 AM
