1969 f100 custom cab Back up lights
Included with the neutral safety switch on top of the column under the dash.
There is four wires coming from it. two for safety switch and two for back up light circuit. I think the back up wires are black with red tracer? Seems to be, maybe I'm cornfuzed.
Try this, put in reverse and with someone looking at the rear of truck, wiggle the shifter up/down a bit. Might be just out of adjustment enough to not function. Common problem, next to not starting due to neutral safety switch potion out of adjustment. There are two small screws that hold switch to column. Loosen and adjust.
C7TZ-7A247-A .. NSS (Motorcraft SW-600) / Located on steering column / Obsolete ~ Available from auto parts stores.
Applications: 1967/77 F100/350.
D0TZ-7B097-B (replaced C5TZ-7B097-A & D0TZ-7B097-A) .. NSS Selector Lever / Obsolete ~ 1,000's available NOS
Lever attaches to shift tube thru hole in steering column shroud, has a knife blade end that fits in NSS, it's notorious for snapping off.
Applications: 1965/77 F100/350.
well I climbed under the truck and everything seems to be there I am guessing switch is prob bad. It is missing the wire that goes from square plug on wire harness to the trailer hitch type plug that goes to switch on column. The square plug has a jumper for neutral and toggle switch is wired to lights. Does anyone know where I can get the trailer type to square connector wire for this?
Smirks90
12-14-2014 07:57 PM
shruck
19
03-04-2013 10:24 PM
hairyboxnoogle
09-19-2011 07:44 PM
Sycostang67
04-17-2009 01:15 PM
