Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
inboard CV joints "Knocking"
Old Mar 26, 2014 | 11:35 AM
Deebo's Avatar
Deebo
I have a 05 Ford escape with 107K.
When I make a right turn and applying the brakes I feel a clunking in the brake pedal. checked all front brakes and all is ok. So I looked at the drive shaft on the drivers side. I can move or wobble the drive shaft around on the in board CV going in the transmission. Is that normal? there are no "Clicking" sounds any where while turning which would tell me that is what it is.
Also while driving slow not appying brakes there is a lot of clunking and knocking sounds while going over a few little bumps here and there.
Is it the inboard CV joint? Please advise.
Old Apr 4, 2014 | 09:42 AM
bmuhlbach's Avatar
bmuhlbach
The inboard joints don't go bad often.I would go with the sway bar end links. I replaced them on 2 Escapes to have the new ones fail after a few months thank goodness for warranty on them. So far been quit for 2 yrs.
Old Apr 4, 2014 | 09:45 AM
Deebo's Avatar
Deebo
Thank you much! it'd the same story here. I put Moog bars on it about 6 months ago and I think your on it getting one today.
Old Apr 5, 2014 | 09:49 PM
bmuhlbach's Avatar
bmuhlbach
Also check the tie rod ends they can clunk.
Old Apr 7, 2014 | 05:31 AM
Deebo's Avatar
Deebo
Thanks for updates.
Changed both sway bar links. Still a knocking sound. Going to drivers side Tie rod next.
krewat
Apr 23, 2014 08:25 AM
armydude
Nov 20, 2010 04:12 PM
rtazz17
Jun 21, 2009 08:22 PM
CounterMaker
Aug 11, 2007 07:43 AM
fishead0719
Dec 14, 2005 03:16 PM
