I need a pulley
Old Mar 25, 2014 | 09:30 PM
helifixer's Avatar
helifixer
I need a pulley
I am working on my fathers '68 f500, it has the FT 330 hd and I need a 3rd pulley on the harmonic ballancer, I have found them for the 390's but not for the 330.
any help[ on where to look or if anyone has one they want to sell let me know.
Thanks
Old Mar 26, 2014 | 05:28 AM
User 71024's Avatar
User 71024
do you have a description? I have a setup out of a 67 F-600 with a 360. Not sure if it's the same.
Old Mar 26, 2014 | 09:16 AM
trozei's Avatar
trozei
I think he wants a three groove crank pulley.
Old Mar 26, 2014 | 09:17 AM
helifixer's Avatar
helifixer
I think it would have to be from an industrial engine ie. 330 361 or 391, in the FT HD series with the large crankshaft.
I will measure and get some pics of the harmonic for size reference.
Old Mar 26, 2014 | 10:16 AM
helifixer's Avatar
helifixer
that would work, or there are add on pulleys that bolt to the 3 bolt holes used to mount the puller to remove the harmonic.
Old Mar 26, 2014 | 10:19 AM
helifixer's Avatar
helifixer
here are the measurements
hope the file works it is pdf.
hand drawn not to scale
ford 330 ac pulley measurments0001.pdf
Old Mar 26, 2014 | 11:26 AM
JEFFFAFA's Avatar
JEFFFAFA
Thanks
Are you replacing one that is there or adding one on?
Old Mar 26, 2014 | 11:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I am working on my fathers '68 f500, it has the FT 330 hd and I need a 3rd pulley on the harmonic balancer, I have found them for the 390's but not for the 330.
This is what your truck has now: C4TZ-6312-A .. Double Sheave Harmonic Balancer / Marked: C4TE-6316-A / Obsolete
Applications: 1964/78 330 H/D, 361 & 391.
The thing is, there's no such thing as a FT triple sheave harmonic balancer. Ford only offered a double sheave accessory outer pulley for your application.
Accessory outer pulleys bolt to harmonic balancers to add P/S and/or A/C and/or dual belt alternators.
C4TZ-6A312-B .. Double Sheave Accessory Outer Pulley / Marked: C4TE-6A359-B / 3 5/32" long, pulley diameters 6 59/64" & 5 53/64" / Obsolete
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201 / No Ford dealer, no other obsolete parts vendor has any.
Old Mar 26, 2014 | 12:02 PM
JEFFFAFA's Avatar
JEFFFAFA
Bill. I looked also. I'm thinkin' he either has an aftermarket add-on A/C pulley bad or he wants to add one on.
Old Mar 26, 2014 | 12:06 PM
NumberDummy
Wants to add one would be my guess. I found two of the little charmers NOS
Old Mar 26, 2014 | 07:32 PM
helifixer's Avatar
helifixer
adding a 3rd one for a belt driven hydraulic pump. we found a pulley on an old 289 that had the right bolt pattern just had to move the pump 1/2 inch fwd to align the belts.
Thanks to every one who had input on this.
beartracks
Jul 4, 2016 12:23 PM
Badmoonreizen
18
Apr 20, 2016 06:34 PM
RIKIL
May 31, 2014 06:44 AM
dyoungen
Oct 13, 2012 09:08 AM
