engine swap
Old Mar 25, 2014 | 09:02 PM
qprof's Avatar
qprof
engine swap
Does anyone know if a 1999 7.3 powerstroke diesel out of a 4700 international work in a 1999 f250 superduty powerstroke?
Old Mar 26, 2014 | 03:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
it will bolt in, but you may have differences in engine electrical. the international DT444-E is the same physical engine but it uses a bunch of different things than ford uses on the powerstroke 7.3
Old Mar 26, 2014 | 03:51 AM
SpringerPop's Avatar
SpringerPop
Most likely the International has single-shot injectors, and the Ford PCM is set up for split-shots.
There are other things, most of which can be switched over, but expect some software differences.
Pop
Old Mar 26, 2014 | 08:43 AM
snakedoc's Avatar
snakedoc
front covers, injectors, sensors, wires, and maybe the fly wheel adapter.
Old Mar 26, 2014 | 08:49 AM
Pikachu's Avatar
Pikachu
I'm pretty sure the AC single shots were only used from 94-96, and only in certain engines; the high torque and high output models.
Galaxie mike
Apr 11, 2016 09:24 PM
qprof
Mar 26, 2014 05:16 AM
parkland
19
Apr 26, 2008 04:15 PM
crbav8r
Jul 18, 2005 08:44 PM
