year swap 7.3
Old Jul 18, 2005 | 08:32 PM
crbav8r's Avatar
crbav8r
year swap 7.3
What year 7.3 will bolt into a 1999 F450. (how far back)?
Old Jul 18, 2005 | 08:39 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
a 1999 is the earliest that had the intercoolers, i dont know if non-intercooled pre'99 engines will bolt in. i would go for the highest year you can find for the power increase
Old Jul 18, 2005 | 08:44 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
As far as physically bolting in, any 6.9-7.3 will bolt in. For your current electronics to work right you need a 99-03. A 94.5-97 will work fine if you either swap your split shot injectors into the older motor or use the computer out of the older truck to run the single shot injectors in the old motor.
