Coil spacers?
Old Mar 25, 2014 | 02:31 PM
Biggiefiggie's Avatar
Biggiefiggie
Talking Coil spacers?
Hi, I have a 1996 ford f150 single cab, short bed, 2wd, 5.0 v8. I just recently bought 16 inch rims and new mud tires. I was hoping to get alittle more clearance in the front by leveling it out. Or if possible make kind of a stance by lifting the front end higher than the back end. What's the cheapest and most reasonable way to do this? I read about coil spacers, any reviews and luck? Thanks for the help
Old Mar 25, 2014 | 04:01 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
i am not a fan of coil spacers. i would look for taller coil springs.
Old Mar 25, 2014 | 04:11 PM
Biggiefiggie
Thank you for the warm welcoming lol. But cheaper wise. And easiest installation. Would coil spacers be the way to go. Why do you prefer coil springs over coil spacers. And wouldn't new springs make it a really stiff ride?
Old Mar 25, 2014 | 04:19 PM
tjc transport
i ain't rite
well, you have to take the springs out to put the spacers in, so it is not any easier to use the spacers.
and i have seen springs not seat properly in the spacers, or move in them.
i also had a few vehicles towed in that had the springs pop out because the spacers were not done properly..
Old Mar 25, 2014 | 04:47 PM
Biggiefiggie
Lol. But in order to put new springs on. You also have to take the old ones off. So for both ways, taking the springs off come into play.
Old Mar 25, 2014 | 06:10 PM
tjc transport
i ain't rite
correct.
what i meant was, some people think just tossing a set of spacers in is easier than putting in new springs. it is actually a few more steps, and takes longer to do than just popping new springs in.
Old Mar 25, 2014 | 06:21 PM
danr1's Avatar
danr1
I think this is what you're looking for,
Amazon.com: Mr. Gasket 1280 Universal Coil Spring Control - Set of 2: Automotive Amazon.com: Mr. Gasket 1280 Universal Coil Spring Control - Set of 2: Automotive
or easier/quicker yet,
Mr. Gasket/1 3/4 in. jumbo front coil spring booster (1283) | Coil Spring Booster | AutoZone.com
Old Mar 25, 2014 | 06:30 PM
White Mountain Goat's Avatar
White Mountain Goat
Go with new springs, there's a ton if information on here about them. Someone put those screw in spacers in mine before I bought it, I replaced the springs with Moog 844's and it lifted it even more. My alignment guy says that the spacers that go between the coils make it harder to line the front end back up.
Old Mar 25, 2014 | 07:26 PM
ravens fan's Avatar
ravens fan
i agree go with new springs, i went with the spacers because they were cheaper but i think they ride worse than regular springs. They were also a pain to get in as my old springs still have plenty of life and weren't easy to compress
Old Mar 25, 2014 | 07:38 PM
Bob Gervais's Avatar
Bob Gervais
All depends on how much you want to lift it. What size tires did you get?
Old Mar 25, 2014 | 09:47 PM
Biggiefiggie
33's mud claws. With 16 inch rims
Old Mar 26, 2014 | 05:22 AM
Bob Gervais
To clear those on a 2wd, you're going to want at least a 2.5" lift, preferably a 4". Here's some options that aren't extremely expensive: 1995 Ford F150 Suspension Lift Kits
You could do a 3" body lift as well.
ravens fan
18
Feb 23, 2011 05:46 AM
92exploder
1978 - 1996 Big Bronco
Feb 26, 2004 10:24 PM
chevenstein
Aug 1, 2002 01:50 AM
