1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Which lift do I have??
Old 03-24-2014, 06:57 PM
MDSLIGHT's Avatar
MDSLIGHT
MDSLIGHT is offline
I bought a 2003 F250 CC 4x4 short bed recently that I was told has a 6" pro comp lift on it. After pulling up next to my buddies F350 who has a 8" pro comp lift I question if it is really an 8" lift. My truck was slightly taller than his truck. I am not sure how I can tell which lift I have. Both 6" and 8" use the 22610 front leafs which is what is stamped on the front leafs of my truck. Also I want to get some bilsteins for my truck. I took off the shocks that are on the truck now and measured the extended length. They measured 35"s roughly long. Is there a way I can measure the connecting points on the truck to know what length of shock to get? Thanks for any info..
Old 03-25-2014, 05:33 AM
redford's Avatar
redford
redford is offline
Received 1,624 Likes on 948 Posts
There are a lot of variables involved. You might want to just post a picture of your truck.
Old 03-25-2014, 07:58 AM
OneTon350's Avatar
OneTon350
OneTon350 is offline
I have an 07 350 with a fabtech 6" lift.
A bud used to have a 05 250 with a 6" lift
and was taller than me, both on 37"s.
I never understood why. Stock one tons are already
a bit higher than a stock 3/4 ton. I recently replaced
my rear springs because one side was cracked.
When I installed the new "ProComp" 6" springs
it sits 2" higher in the rear now. Now I need to
raise the front to make it level.
btw, is your rear factory block 1 1/2" or 3"?
Old 03-28-2014, 05:32 PM
MDSLIGHT's Avatar
MDSLIGHT
MDSLIGHT is offline
Old 03-28-2014, 06:15 PM
MDSLIGHT's Avatar
MDSLIGHT
MDSLIGHT is offline
Old 03-28-2014, 07:53 PM
Snowdrift3r's Avatar
Snowdrift3r
Snowdrift3r is offline
What are the good leveling kits?
I want to put a leveling kit in my 07 Superduty Crew, any recommendations?
egreco79
02-19-2014 03:00 PM
warnecke13
13
01-18-2012 11:27 PM
cliwel
06-09-2011 01:35 PM
73BlackBeauty
Offroad & 4x4
11-14-2008 07:15 PM
Dizz0129
07-24-2007 02:27 AM
Quick Reply: Which lift do I have??
