Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Electrical shocks
Old Mar 24, 2014 | 12:06 PM
RA72725's Avatar
RA72725
Banned
Electrical shocks
Why do I get an electrical shock when I touch my 2005 Escape? It's not like I drag my feet on a carpet prior to touching it. I had same issue on an other vehicle.
It is very annoying - what should I do? Help me please....
Old Mar 24, 2014 | 06:38 PM
wptski's Avatar
wptski
Static electricity, I've had that all my life! Worse in dry winter time.
Old Mar 24, 2014 | 07:10 PM
projectSHO89's Avatar
projectSHO89
Cheap tires and cheap polyester leisure suits don't go well together.
Old Mar 25, 2014 | 05:15 AM
RA72725's Avatar
RA72725
Banned
Funny Boys - but seriously?
I was expecting something about ground wires...
Old Mar 25, 2014 | 06:11 AM
projectSHO89
It's the tires. Insufficient carbon black content in the rubber formulation.
You can install a ground strap that hangs down and touches the ground when the vehicle is stopped.
Old Mar 25, 2014 | 06:47 AM
RA72725's Avatar
RA72725
Banned
I'll look into that ground strap.
But I don't think I have cheap tires : iceGUARD iG51v Yokohama...
Old Mar 25, 2014 | 08:47 AM
tomw's Avatar
tomw
Use your car key as the electrode. Hold it by the plastic handle AND the metal part, and bring it close or touch it to the car before you touch it with your digits. Any built up juice will dissipate through the key tip rather than your fingertip.
One other thing to do, if you have fabric seats, is to spray them with fabric softener, diluted as you see fit. You can also spray the carpet with fabric softener the same way. It will then become a slight conductor, and dissipate any static built up.
If you have vinyl or leather seating surfaces, you might try one of the Meguiar (sp?) care products as it might reduce static or increase dissipation of the charge. Not sure on that, but fabric softener does work.
tom
add: Warning, you might slide around more after use as you won't have that "Static Cling"(tm) keeping you glued to the seat.... heh
Old Mar 25, 2014 | 10:41 AM
projectSHO89
It's really not an issue of the cost of the tires, that was in jest.
What causes it is the ratio of carbon black vs silica in the rubber compound. Many modern low rolling resistance tires have increased the silica (non-conductive) component while decreasing the amount of carbon black (conductive). This turns the tires into insulators instead of conductors, so the accumulated static charges don't bleed off to ground as readily.
F350-6
6.7L Power Stroke Diesel
13
Oct 6, 2017 07:01 PM
F350Jay
Jul 25, 2012 09:24 AM
4wheelfurry
Apr 21, 2008 08:03 PM
ssKable
Feb 8, 2005 02:21 AM
synergy46
Nov 30, 2004 01:51 PM
