Chip question
Old Mar 24, 2014 | 10:43 AM
farmert's Avatar
farmert
Chip question
Hearing of you guys running a chip, and I couldn't stand it any more, so I found a TS chip that is susposed to have Tony Wildman's tunes, for cheap. But it only has 3 tunes fast idle, extreem, and no start. No stock sitting. Kind of weird choices I thought, but it didn't cost much. The problem I'm having is it will randomly go to fast idle, then return to normal without touching the control ****. When it goes to fast idle, turning the control **** does nothing. I can drive the truck, and will drive as normal, other than it won't idle below 1200 rpms. What is going on, did I install it wrong, or is there something messd up with the chip?
Old Mar 24, 2014 | 10:49 AM
brad_97stroker's Avatar
brad_97stroker
My guess would be the chip. Though I have never delt with the change on the fly chips before. Where did you get the chip at?
Old Mar 24, 2014 | 12:37 PM
427 fordman's Avatar
427 fordman
It could be a faulty control switch Tom. I think the only way to know is try a different one. You could send Tony and email or call him and see what he says. I think high idle is just the stock tune with the high idle.
Old Mar 24, 2014 | 08:35 PM
farmert's Avatar
farmert
Thanks for the replies guys. My first thought was the wires were jumping across the terminals on the switch, but they looked good when I checked. When it decideds to change to fast idle, or back to normal it will give a surge of power that lasts for 1/4-1/2 second. Just long enough to tell me it changed. I'll just keep driving it for a while and see if it gets better or worse.
Old Mar 24, 2014 | 08:41 PM
ReBilld's Avatar
ReBilld
I would say that is a faulty chip. I'd do what Darin suggested and call or email Tony.
Old Mar 25, 2014 | 12:29 AM
oldbird1965's Avatar
oldbird1965
Is the extreme tune extreme?
Old Mar 25, 2014 | 08:35 AM
farmert's Avatar
farmert
Well it is extreme as my stock injectors will let it. It does have more power, and it will puff smoke if i lug it. I have never seen any of my trucks smoke, other than cold start smoke.
BBslider001
Apr 13, 2017 01:52 PM
4inchlovin
Apr 8, 2014 09:02 AM
97powersmoke
Nov 3, 2008 10:45 AM
02FX4
Computer Chips & Tuners
Jun 2, 2005 06:14 PM
gatorpsd
Apr 9, 2005 07:39 PM
