idle rough
Old Apr 9, 2005 | 07:18 AM
gatorpsd's Avatar
gatorpsd
idle rough
I have a 1997 f250 7.3L 4x4. Put in a chip last week everything ok. change my fuel filter two day a go. Left the truck idling at work for about 30min came back it had died. At a red light the idle will go up and down. Sometimes almost choke out. Drives like a champ. Maybe the fuel filter? not sure. tell me what yall think.
Old Apr 9, 2005 | 08:00 AM
CAT_man_963's Avatar
CAT_man_963
If it was the fuel filter - I wouldn't think it would just affect the idle - but I could be wrong. You said you got a chip - so the first thing I would probably do is pull the chip and see if it still does it. My truck idles a little different with my chip set on the higher settings - not that it would die or anything though. I'd pull the chip to rule that out first....
Old Apr 9, 2005 | 10:51 AM
krzyk26's Avatar
krzyk26
If it stills does it after pulling the chip get your codes read and let us know.
Old Apr 9, 2005 | 11:28 AM
vancouverpower's Avatar
vancouverpower
Why did you let it idle for 30 minutes? I'm sure this had nothing to do with it dying, but it's not the best thing to let motors idle that long.
I agree with cat-man, pull the chip and see if that helps.
Old Apr 9, 2005 | 07:39 PM
gatorpsd's Avatar
gatorpsd
I wasn't planning on being so long. Boss man was on my back.
