E150 Air conditioning controls
Old 03-23-2014, 03:37 PM
GA_Boy's Avatar
GA_Boy
GA_Boy is offline
Hi, I have a E150 RV, 302 Cu. In. and I recently installed a new coil. I had to remove the Dog House to do this and some way I bumped some vacuum lines that I think was part of the A/C. I replaced it but there seemed to be 2-3 places it would plug in. I imagine that I guessed wrong. I have a Haynes manual that covers many years and it was not any help. Does anyone have a picture that describes where the small line go?
When I turn the A/C on I can tell that it is producing cold air because I can feel it under the dash. It's just not coming out of the vents.
Thanks for any help.
Marvin
Old 03-23-2014, 07:07 PM
tabijan's Avatar
tabijan
tabijan is online now
What year?
Sixto
93 E150 Chateau 5.8 187K miles
Old 03-23-2014, 08:44 PM
GA_Boy's Avatar
GA_Boy
GA_Boy is offline
Originally Posted by tabijan
What year?
Sixto
Sorry about that-----it is a 1988, E150. The vac (I think they are Vacuum) lines are behind the Coil on the left side. Can't see them from the front. Not sure about underneath but I removed the dog house covet to get to the coil.
Marvin
Old 03-24-2014, 07:19 PM
jimandnena's Avatar
jimandnena
jimandnena is offline
Marvin
Hey Marvin,
I have an '88 Club Wagon. I'll probably be pulling the doghouse off tomorrow, I can shoot photos then. Can you give me an idea of where the vacuum lines should be? The vacuum lines I'm thinking of near the coil are all smog related (I think?).
https://picasaweb.google.com/jimandnena4/DoghouseOff
jim
Old 03-24-2014, 08:07 PM
GA_Boy's Avatar
GA_Boy
GA_Boy is offline
Originally Posted by jimandnena
Hey Marvin,
jim
Thanks for the reply. The line that I knocked off was from a block/group of maybe 5-8 very small tubes (1/8" OD) and it seems that they were color coded. I have a doctor appointment tomorrow but I'll pull my dog house cover off Wednesday. Pictures will certainly help as my Haynes doesn't show them.
Marvin
Old 03-25-2014, 09:51 AM
jimandnena's Avatar
jimandnena
Marvin
I added photos to the album linked above, Marvin. I didn't see anything that looked AC related but I had a thought about the vacuum lines in the last photo. Those lines are connected to the heater/AC control and operate the vent system. If one of those lines got pinched by the doghouse it could affect the AC operation you are having?
I recently dropped the dash to fix a no defroster/floor heat problem, panel air only and had to track the vacuum connections
https://picasaweb.google.com/jimandn...HeaterAirflow#
The airflow defaults to floor/defroster so if the vacuum line to the actuator is pinched, it won't switch to the panel (AC) vents. Does the airflow switch from floor to defroster vents? That is a different actuator but if it changes you know you have sufficient vacuum available.
jim
richkat
07-05-2016 07:45 AM
xkpsanit
08-11-2013 02:39 PM
RIKIL
06-13-2010 08:46 PM
wdstang
12-05-2008 10:45 AM
bigric
1978 - 1996 Big Bronco
05-16-2003 11:41 AM
Quick Reply: E150 Air conditioning controls
