evap/ A.I.R hard lines
Old 07-30-2013, 08:40 PM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
OK, trying to search on mobile sux.
Had a small motor fire on 89 302. Trying to route new lines from DPFE solenoid etc around back of the upper to the right side. Comparing to my 88. Connected red manifold vacuum to the charcoal can, but the 89 has an extra red , didn't trace to source, sorry. Anybody have any ideas what
its purpose was? Tan, yellow and blacks are done. Under Hood decals are different, new part# for 89. They didn't tell much anyway
*edit not charcoal, to the vacuum "coffee" can
Old 07-30-2013, 10:31 PM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
Still trying to learn these systems. When I get off the road, Ill have to see if this truck is supposed to have a purge valve. That's my only guess
Old 07-31-2013, 08:53 AM
Conanski's Avatar
Conanski
Conanski is offline
There is a split(Y) in the red line, it should go to the vacuum can and then feed the TAB, TAD, and EVR solenoids located nest to the coil, and then different colored lines come from each of those devices and go to respective control valves.
Old 07-31-2013, 03:13 PM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
The y musta burned up then, I will see if it is routed to source the controls when I get back.
On the evap line from the TB, there must be some sort of check valve between the ported and manifold taps on the TB. Am I correct, only makes sense that way.
Old 07-31-2013, 04:20 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
I know it ain't an F150, but it should be close.
The EGR gets unchecked vacuum, while the TAB and TAD have a check valve in their supply line.
Old 07-31-2013, 10:15 PM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
I have two taps on the TB, one ported one full. Looks as if they were hooked together (?????) with a T and ran to the charcoal. It is melted so I can't tell if it was some sort of check. Poor mans IAC I guess, this makes no sense. Did somebody Jack a purge valve and start hooking hoses together? ? They list one for an 89 but never seen one installed . BTW 89 150 302 T18 4X w ac
Old 07-31-2013, 11:48 PM
Puddy's Avatar
Puddy
Puddy is offline
hope this helps
and heres a Guide.....
http://www.fordtruckclub.net/forum/s...ead.php?t=6050
The Power of The Internet.
Old 08-01-2013, 09:40 AM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
That is a great illustration. Thank you. Got one for the evap?
Old 08-11-2013, 02:39 PM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
Ok, yes the other red is the source vacuum for the TAB and TAD. The tee melted in the "situation" Now I think I got this back together, I'm actually proud if myself for hooking it back up, not like me.
spooktn
1983 - 2012 Ranger & B-Series
04-14-2018 12:55 PM
Junior Junior
01-17-2014 10:41 AM
RIKIL
06-13-2010 08:46 PM
vancouver island
17
11-01-2009 05:46 PM
lattices2
1978 - 1996 Big Bronco
03-04-2005 09:51 AM
Quick Reply: evap/ A.I.R hard lines
