Headlight
Mar 23, 2014 | 11:18 AM
Headlight
01 Superduty headlight burnt out.
Its a sealed beam, havnt changed one of those for years. Most are bulbs.
Anyway I took all the screws I could see from around the headlight door,
and underneath it.
Headlights still in there as solid as when I started.
Anyone know what screws I seem to be missing?
Mar 23, 2014 | 12:54 PM
Its nice to see Im not the only one on here to dumb to change a headlight?
Nobody else seems to know either?
Mar 23, 2014 | 01:29 PM
pull the door off, then remove the 2 or 3 screws that hold the retainer ring to the light bucket.
Mar 23, 2014 | 01:47 PM
Quote:
Originally Posted by
tjc transport
Ya ya getting the door off is the problem......................
That's what I figured also.
Mar 23, 2014 | 03:47 PM
when in doubt, use a bigger hammer!!
Mar 23, 2014 | 06:29 PM
tjc transport
I could bust the door out and get to headlight but it might look kinda ugly
Mar 23, 2014 | 07:09 PM
mehhhh. that's what they make duck tape and rattle can paint for.
Mar 23, 2014 | 07:13 PM
Canadian Tire will change it maybe if I buy a headlight there ............let there people break it.
Mar 23, 2014 | 09:15 PM
C-4 Universal disassembler tool.
Does the job every time.
Have you tried Youtube?
This is the wrong type for you and the only one I could find.
I did dig up the 03 sealed beam replacement steps if that helps.
Sean
Mar 23, 2014 | 10:22 PM
Go to owner.ford.com and pull down a PDF of your owners manual. I use it more then going out to the truck to open mine up. Nice resource.
Mar 23, 2014 | 10:59 PM
Yahiko
Thanks I found that one also but its different.
Mar 23, 2014 | 11:00 PM
Bazillions
I shall try that thanks.
I thought maybe someone owned one of these and had to change a headlight.
Mar 23, 2014 | 11:16 PM
Vinford
Did you also look at the PDF that I attached at the bottom of the post?
That came from the Ford 2003 Shop Workbook.
Sean
Mar 24, 2014 | 08:06 AM
Yahiko
Sean
Didn't see that , but it is what mine is.
I took those screws out, Ill try again.
Thank you.
Mar 24, 2014 | 10:29 AM
Vinford
i actually did, but it was way back in 04 or 05 before i got senile and started forgetting what i had for breakfast this morning.
