Battery drains completely down
Old Mar 22, 2014 | 04:29 PM
CharlieLed's Avatar
CharlieLed
Sounds like the alternator is not working...most Sears service centers will check it for you at no charge.
Old Mar 22, 2014 | 05:10 PM
Tedster9's Avatar
Tedster9
You know enough to test the alternator now, basically. Maybe better than AutoZone or Sears?
What's the temperature?
First start with a fully charged battery. A cold battery is tougher to charge (internal resistance) than in hot weather. What confused me at first during troubleshooting was the vehicle (at least off idle) isn't running off the battery at all, whether alternator or generator. The battery is basically a filter, and primarily for starting or the radio when parked. Other than that the charging system carries the load.
Figure 5 amps (each) for headlights, maybe 5 amps for the ignition? So if there's any problem with charging it will show up quick. Just a start cycle for a split second with even a healthy starter will really draw a battery down. If the battery reads 12.5 at rest that's about a 75 per cent charge. If it's even chilly and the battery is weak, headlights, then you're going to want to see closer to 15 volts for a while at say 1500 RPM and then it will settle down.
Old Mar 22, 2014 | 08:40 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
A lot of good information from a lot of smart people so far . One thing I didn't notice being mentioned is, use caution around a charging battery. For sure on the water/acid type of battery (I'm not so sure on the Gell or optima rap type). A charging battery will give off explosive gas, so be very carful, use eye protection, and make sure your last connection is the negative to the frame while testing(with a jumper if necessary)to keep any spark away from any source of battery gassing. I saw a guy blow up a battery while charging it. Im no expert so if any one cares to elaborate on this part of it please go for it, it wont hurt my feelings. Safety first.Good luck
Old Mar 23, 2014 | 12:15 AM
Tedster9's Avatar
Tedster9
Not just sulfuric fumes or dangerous fire/explosion hazards, also just plain toxic gases that are not good to breathe.
If a battery is kept charged though, it doesn't need to spend hours and hours charging, if that makes any sense, and the fumes will be minimized.
Old Mar 23, 2014 | 09:33 AM
big job's Avatar
big job
Just a thought, I have one truck being a 1954 F900, still has the Lincoln
but was converted to 12vt positive ground with a big 100amp Leece Neville
alternator (this was done back who knows when) I had to install cole hershey disconnect switch on the floor (all my big jobs got them) so one
day and overnite the battery is dead. The parasite is the alternator with
internal regulator. I think its going to get a one wire 90 amp neg ground
alternator, but I just dread flipping the wire on the ampmeter cause of all
the air lines and no room and the jungles of wires previous owners did
(no problem its called side snips) and also my tip is, on all my trucks when
I freshed up under the dash, I added two feet to the instrument cluster
with a disconnect, only thing to disconnect is speedo cable and place the
whole cluster on your lap. Why? its to get at the dispicable wiper linkage.
Old Mar 23, 2014 | 02:20 PM
arctic y block's Avatar
arctic y block
With out any computerized fuel injection chit on your truck it won't hurt to pull
off the Neg cable while it is running. If it dies when this is done that it ain't charging.
It's as simple as that.
Old Mar 23, 2014 | 02:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That isn't a good idea with some alternators, they need the battery for reference voltage.
Old Mar 23, 2014 | 02:42 PM
arctic y block
I have heard that too Ross. But I have never seen one. Must be a new
style alt that I have yet to see. What will happen if it has that style of alt
on it? I can not for the life of me think what it could damage. The alt?
Old Mar 25, 2014 | 01:26 PM
petemcl's Avatar
petemcl
Originally Posted by abeagle
If the alternator was not charging, would the engine die while running? It seems to run fine once started and idling well.
No, the engine won't die until the battery power drops below the voltage necessary to run the ignition system. That voltage is nowhere close to what you need to run your starter. I'm not sure what year truck you have but if your ammeter works you can tell from that when you have a negative draw. If you have no ammeter then as others have recommended I would get your generator output checked.
Old Mar 25, 2014 | 01:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Here's a decent discussion: disconnect battery = kill alternator, question: Grassroots Motorsports forum: Grassroots Motorsports
Like the post by "Angry Corvair Super Dork" (LOL) says, a 3-wire type alternator adjusts output by looking at system voltage. If it doesn't see a battery voltage, it ramps up output thinking the battery is way low. It "may" fry the regulator or components of the car due to overvoltage.
Old Mar 25, 2014 | 01:56 PM
abeagle's Avatar
abeagle
Wow, with all the possible options and possible hazards for a slow burning candle like me, I am worried about screwing up more things and more important things in trying to find the problem. What are the major problems I need to avoid? I blew out some electrical with the brake lights trying to find a short once before so I have experience in screwing up. At least I can charge it now and have it run.
Old Mar 25, 2014 | 02:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Just to be real clear about what we're dealing with, do you have an alternator; a 3-wire or 1-wire? Generator with regulator?
Old Mar 25, 2014 | 02:42 PM
  #28
abeagle's Avatar
abeagle
One wire alternator.
Old Mar 25, 2014 | 02:49 PM
  #29
raytasch's Avatar
raytasch
Believe Nothing
Very simple, no possibility of damaging anything, way to determine if the system is charging:
1. Obtain a volt meter. Lowes, HD, many places sell in expensive meters. Playing with an old truck, you need a meter. An alligator clip is needed for the leads or someone to help with this exercise is recommended .
2. Set meter to DC volt scale.
3. Put positive meter lead on positive post of battery.
4. Put negative meter lead on negative terminal of battery.
5. Note reading of meter....Should be around 12.5 volts.
6. Start vehicle.
7. Raise engine speed a few hundred RPM or more.
8. Repeat steps 3 thru 4.
9. Meter should show more than 12.5 V and less than 15 V. if the generator or alternator is working.
Old Mar 25, 2014 | 03:14 PM
  #30
harleymsn's Avatar
harleymsn
Don't know if this will apply here. When I first got Edith back together, I found that if she sat for a week or more it drained the battery down to where I didn't have enough to start her. It took me a day to find the culprit, when I installed the one wire alternator, I installed a volt meter in place of the amp meter. I connected the meter directly to the alternator and found that when the truck was not running, the meter was drawing indirectly from the battery.
