Mistress Build Thread
Old Apr 9, 2014 | 04:19 PM
  #76
martin72's Avatar
martin72
Originally Posted by DIYMechanic
The steel wool SOS pads? I would imagine that would work really well for the brake dust on the inside. I have had some good results in the past with just a mild scotchbrite pad so I bet the SOS pad would work really well with the soap that comes in it.
I ordered a Harbor Freight buffer yesterday. I've needed one for a while now, and this is a good excuse to get it. Had a coupon anyway so if it ends up being junk I'm not out a lot. Looks like you're using a lamb's wool bonnet on the buffer to do your polishing, correct?
It is lamb wool but not a bonnet it is a velcro (they call it hook and loop) pad. I bought my locally but here they are you need both 743052-5 screws on the buffer and 192629-7 velcro's onto it. This is cheap for them I gave this much for the one that screws on.
Makita 192629-7 7-Inch Hook and Loop Pad for 9227C Sander/Polisher Makita 192629-7 7-Inch Hook and Loop Pad for 9227C Sander/Polisher
by Makita
Makita 743052-5 7-Inch Hook and Loop Back-Up Pad Makita 743052-5 7-Inch Hook and Loop Back-Up Pad
by Makita
Old Apr 9, 2014 | 06:07 PM
  #77
fordman67's Avatar
fordman67
those wheels look as if they were polished at one time. I did a set of terrible valve covers for my old mustang and a set of 428cj valve covers.they were the worst pieces I have ever brought back from the dead. At its worst 1000 grit will be a good start. I would wager that 1500 or 2000 will be actually a good start for sanding. I would first try some alluminum polish and a rag or a buffer like kevin is suggesting. We used to remove the wheels from our mustangs back a long time ago and wheel them in the living room. I would just spend the afternoon on the floor wearing my finger prints off.
Have fun!
Old Apr 10, 2014 | 06:00 AM
  #78
DIYMechanic's Avatar
DIYMechanic
Yes, the wheels were polished. I spent several hours cleaning them up with various aluminum polishes and a rag to get them to the point that you see in that picture. They don't look that well now after seeing some use this winter. I'll try some polish and the buffer when I have a chance and we'll see what results that produces.
Thanks for the input guys.
Old Apr 11, 2014 | 05:16 PM
  #79
ReBilld's Avatar
ReBilld
I'm stopping by Harbor Freight tomorrow
Old Apr 11, 2014 | 09:29 PM
  #80
martin72's Avatar
martin72
We got the old exhaust out today and the new down pipe in with enough clearance not to rub. Only got to work on it about 2.5 hours so I think we got a lot done in a short time my father-N-law helped me today and tomorrow petrokiller is coming up to help tomorrow.
Here is my first cut Bill Showed me where to cut the old down pipe when he was here getting his bed Thanks Bill it worked good we had the whole exhaust out in less then a hour.
With part of the down pipe removed.
It was hard to get the rubber mount off under the truck so I just sawzalled them off the pipe since it is going to scrap anyway.
I cut the pipe in several piece to get it out of the truck the sawzall cut thought it like butter.
Sorry about the shadow's in the pics
under the truck before we removed the old exhaust.
New down pipe
New down pipe
I did not take pic from the top with the new down pipe I will get some tomorrow. We should get finish tomorrow. More pics tomorrow of it finished.
Old Apr 12, 2014 | 09:23 PM
  #81
ReBilld's Avatar
ReBilld
Lookin good buddy! I can't remember....did you get 4" or 5" exhaust?
Old Apr 13, 2014 | 06:47 AM
  #82
DIYMechanic
Looking good Kevin! Keep the pictures coming.
Old Apr 13, 2014 | 11:32 AM
  #83
martin72's Avatar
martin72
Thanks Bill, 5" and it take up a lot of real estate.
Old Apr 13, 2014 | 12:22 PM
  #84
martin72's Avatar
martin72
I want to thank Brad (petrokiller) for coming up Sat. and helping with the install of the 5" diamondeye stainless exhaust on the Mistress. It went really well but let me tell you 5" exhaust takes up a lot of real estate there is not much room left after the install.
Down pipe from the top.
Brad showing how much difference there is in 3.5" and 5"
after the install.
I used band clamp instead of the clamps that came with the kit. I did use the clamp that had the hanger on them that was supplied in the kit.
Pic threw the wheel well over the rear end.
Old Apr 13, 2014 | 12:28 PM
  #85
martin72's Avatar
martin72
Me and Brad took a little ride after the install and I could tell a big differance in the sound and performance it has a real throaty sound now.
Old Apr 13, 2014 | 12:55 PM
  #86
oldbird1965's Avatar
oldbird1965
I learned my lesson on not using band clamps! If there is a possibility of needing to take it apart in the future, use band clamps. I have band clamps on all mine now except one joint that I couldn't get apart. The clamps with hangers you have to use. Looks great Kevin!!
Old Apr 13, 2014 | 02:29 PM
  #87
DIYMechanic
Man, that thing looks sexy!
Old Apr 13, 2014 | 06:01 PM
  #88
petrokiller's Avatar
petrokiller
Kevin it was my pleasure to lend a hand. Honored to have worked on the MISTRESS!
I can now say I worked on a clean truck instead of looking at one at a show.
Brown Truck was intimidated with his tiny pipe heading to Georgia. LOL
Old Apr 13, 2014 | 09:34 PM
  #89
martin72's Avatar
martin72
Thanks Glenn, I had seen somewhere not to use the suppled clamps it may hve been on your thread.
Thanks Nate
Thanks for driving two hours just to help a brother out.
Old Apr 13, 2014 | 09:39 PM
  #90
ReBilld's Avatar
ReBilld
Now I am really jealous! I want to do 5" exhaust on mine so bad! I bet it does sound good! Nice job guys...and reps sent to Brad!
