Blowby
Old Mar 21, 2014 | 12:25 PM
Rayrider911's Avatar
Rayrider911
Blowby
Hey guys this engine is freshly built with maybe 4000 miles on it had some issues being first time build had a lot of clattering took her to machine shop found out pushrods were 100 thousandths short got it back ran okay but then I noticed it had a lot of blowby idk if it was the shop or what any idea on this rings, head gasket etc... PVC works. If I get on it it will pop my dipstick out and throw oil all over headers and undercarriage quite a bit of oil. It kind of chugges when a loads put to the engine in high gear like goin up hills.Plan on a compression test tomorrow.
94 f150 5.8
Rhs heads
Edelbrock intake
Little bit larger cam
Old Mar 21, 2014 | 03:39 PM
timbersteel's Avatar
timbersteel
Blowing dipstick out means high crankcase psi.
Thoughts are...
Oil level to high
PCV valve hose restricted
Fresh air intake tube restricted
Rings not seated..? Synthetic oil used to early after break in?...
When did the blowby start? Before or after pushrod length was corrected?
Old Mar 22, 2014 | 02:00 AM
Rayrider911
I'm not 100 % I noticed it after pushrods were fixed but defiantly got worse not it's white smoking out exhaust but not anti freeze comin out not a sweet smell
Old Mar 22, 2014 | 02:25 AM
Rayrider911
I mean is white smoking and it will build up enough pressure to drain bout all the oil
Old Mar 22, 2014 | 07:31 PM
eakermeld's Avatar
eakermeld
Did you build this engine or did a shop do it?
Old Mar 22, 2014 | 08:36 PM
joey2fords's Avatar
joey2fords
something has gone horribly wrong.
time for a leak-down test; unless, of course, a shop did this, then they should probably pay to have it towed in and make good on their work.
Old Mar 22, 2014 | 09:09 PM
eakermeld's Avatar
eakermeld
That's exactly where I was headed. Something like .010 pistons in .030 holes or ring gaps to big or clocked wrong or who knows what.
Old Mar 22, 2014 | 09:36 PM
Rayrider911
I built the top end bought it as rebuilt short block from Forbes shop ism doin compression check Sunday and I'll get back with y'all it will only push the dipstick out and oil when getting on it as well as the smoke... It's been a dissappointing build
Old Mar 22, 2014 | 09:48 PM
joey2fords's Avatar
joey2fords
the leak-down test will give you more leverage with the shop than a compression test. since you did the top end they could well try to point the finger at your work, rather than their own. if a leak-down test shows that leakage is past the rings then they should make it right.
Old Mar 23, 2014 | 04:58 PM
Rayrider911
Okay well I got 150/150 except number 5 &6 had 60/60 y'all thinking head gasket
Old Mar 23, 2014 | 06:08 PM
Rayrider911
Also put oil straight in spark plug hole and got the Same 60 reading but holding psi it is using coolant and oil is in my air cleaner
Old Mar 23, 2014 | 06:52 PM
timbersteel
Head gasket seems probable cause. At this point, I would be inclined to bite the bullet, pull engine.
Reason I say this is because once coolant has been cycled in the crank and internals, it acts like acid on bearings and iron.
A fresh set of bearings on crank and rods would be 1st on my list. Yeah its lengthy now, but it may prove a burden later down the road. Also doing major R&R with it still in truck may seem worthy, but its hard on the back, knees, and neck. On an engine stand proves so much easier and less lip biting if you make a mistake that cost more hours when its still in the truck.
Others may chime in to prove me otherwise.
Old Mar 23, 2014 | 07:58 PM
eakermeld's Avatar
eakermeld
I did the lower end of my 460 in the truck and NEVER AGAIN will I do that! I could have pulled it out and put it back in the time I spent walking around the shop saying bad words!
Old May 4, 2014 | 09:21 PM
Rayrider911
alright guys sorry for the late reply. i bit the bullet pulled the motor and sent it off the machine shop. results came in yesterday... holes in the pistons... probobly due to detonation. one scored cylinder wall not to bad a hone will fix. so now new pistons, rings, hone, have set up my rhs heads, so basically like getting a long block all for about 800. not to bad. thanks for the responses and the help yall make life a little bit easier.
Old May 4, 2014 | 09:26 PM
eakermeld's Avatar
eakermeld
Glad you found the problem.
fjazzbass
Oct 6, 2014 08:11 PM
-jeremy
Feb 2, 2006 11:11 AM
RC Dan
15
Sep 8, 2005 09:46 PM
Boss_358
Feb 4, 2004 09:08 AM
64bird
Sep 24, 2003 05:35 PM
