Lowering Nox and HC
Old Jul 2, 2003 | 04:35 PM
Mr_Creeper's Avatar
Mr_Creeper
Lowering Nox and HC
I need to lower the HC and Nox count on my 89' Bronco 302.
I've already installed a new EGR valve, changed the plugs and wires, new air filter and air breather, new pcv valve, and started using premium gas.
Is there anything else I can look for or change to nip this in the butt so I don't have to go back twice?
thanks
Old Jul 2, 2003 | 05:15 PM
Cloim's Avatar
Cloim
Lowering Nox and HC
Change your oil. == Seriously. Dirty oil gets past the rings, combusts and throws your count way up.
Fuel injecor cleaner. Run through a full tank of gas. Refill then get test. Don't get the test with the cleaner in the gas, for the same reason as the oil change: you don't want the crap coming out into the combustion chamber during the test.
Make sure the cat is hot when you go for the test.
Old Jul 3, 2003 | 03:12 PM
Mr_Creeper's Avatar
Mr_Creeper
Lowering Nox and HC
injector cleaner in....
oil change this weekend...
then I'll give it another shot...
thanks
Old Jul 3, 2003 | 07:19 PM
79f150TX's Avatar
79f150TX
Lowering Nox and HC
Next time they emissions test it turn the A/C on- on when u drive it there and on when they test it. Make sure it's good and hot before you take it to be tested. The hotter the better. The a/c should help put alittle more load on it and run hotter.
Make sure it's not full of carbon, a good way to blow out carbon is on highway on ramps.
Nick
Old Jul 3, 2003 | 08:28 PM
Mr_Creeper's Avatar
Mr_Creeper
Lowering Nox and HC
hmm, getting the temperature up in the truck might be a problem....
As long as I've owned the truck it's never reached past the "N" in \ \Normal / .
I've replaced the thermostat a few times, but no luck. Even the local dealership couldn't get the temp up (they said they did, but they didn't). I know the gauge isn't broken because last year when towing the camper sitting in traffic it was running pretty hot. Just won't do it under narmal driving conditions.
In the winter the heat is bad in the truck, I always thought that was due to the smaller replacement heater core I put in it.
Old Jul 4, 2003 | 04:48 PM
jrocco's Avatar
jrocco
Lowering Nox and HC
High HC and Nox indicate that you engine is running rich. Since both are high, then your fuel system is just putting too much fuel in the cylinders.
Check fuel pressure to make sure it is within spec. If too high then you need to replace the regulator.
You may need a new O2 sensor. The computer uses this to see how much oxygen is in the exhaust. If this is bad then the engine management computer can not keep the Air Fuel ratio where it need to be.
If your NOX is low and your HC are high then you could suspect that the Cats are not working up to specs.
Old Jul 11, 2003 | 04:17 PM
Mr_Creeper's Avatar
Mr_Creeper
Lowering Nox and HC
Still working on it...
Since I'm trying to clean up the engine compartment at the same time as fixing the emissions, I went to remove the vacuum reservoir (that extra long black coffee can on the passenger's side wheel well) and paint it. Well wouldn't you know it had rusted out on the bottom side.
After a quick run to the local Ford dealer and 33 bucks later....
The truck idles much better and I can breath with the rear window down.
The only thing is though after putting the fuel injector cleaner in, the engine has a slight knock and ping to it when I get on the gas....
anyone know if this is common for atleast the first full tank of gas with the cleaner in it.
Old Jul 12, 2003 | 07:30 PM
zayante's Avatar
zayante
Lowering Nox and HC
I do this with my truck after each oil change. You should see the knock and ping disipare with a fillup after you run out the cleaner. Also low grade fule wiil cause a simlear problem.
Old Jul 13, 2003 | 09:04 PM
68torino's Avatar
68torino
Lowering Nox and HC
What temp thermostat are you running? I would try a 190-195 degree. When to motor runs 'cold' the computer will enrich the mixture because it'sees' the motor as cold. By running rich this is the same as when the choke is on for a carb motor.
skullman1956
1983 - 2012 Ranger & B-Series
Nov 13, 2012 09:48 AM
JohnPeter
Modular V8 (4.6L, 5.4L)
May 23, 2006 02:46 AM
JohnPeter
1997 - 2003 F150
Apr 12, 2006 03:36 PM
nslandscp
May 9, 2004 08:43 PM
