Sponsored by: Real Truck
P0430 code help
Old Mar 20, 2014 | 08:55 PM
5.4f250sd's Avatar
5.4f250sd
P0430 code help
P0430 codes and dash lights on my 06. I have been reading and people say it is either the cats or the o2 sensor.
I am going to replace the o2 sensors first.
If it doesn't work.
Can I replace just the cats by welding in new after market ones?
Old Mar 21, 2014 | 05:42 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, an aftermarket catalytic converter will work, if that is what you need. Check Summit or Jegs for pricing.
Here is a good video on troubleshooting a P0420/P0430 code, despite the fact he's working on a Honda.
Old Mar 21, 2014 | 06:44 AM
projectSHO89's Avatar
projectSHO89
Do NOT blindly replace O2 sensors or a converter.
Do your diagnostics so you can actually determine the underlying reason for the fault code.
The video that redford pointed to describes the testing pretty well. You need to observe the O2 switching to see what the PCM is seeing, then you can determine what the fault actually is.
Old Mar 23, 2014 | 03:23 PM
5.4f250sd's Avatar
5.4f250sd
Thanks guys when it warms up around here I am going to get to work
kjk
Aug 12, 2010 11:37 AM
DTL504
Mar 6, 2010 03:06 PM
71ranchero500
Nov 13, 2005 07:41 AM
jeff45987
Oct 8, 2004 11:44 AM
BExplorer
Jun 14, 2002 12:26 AM
