P4030 Code will not go away
Old Mar 4, 2010 | 09:55 PM
DTL504's Avatar
DTL504
(Correction P0430)
Received the code which stated I had a bad O2 sensor downstream threshold bank 2. I decided to replace the all O2 Sensor and change the plugs but after clearing the code it comes back after a few miles. I have reset the code using an OBD II and taking the NEG BAT cable off for 6 hours. I installed a new complete Magnaflow stainless system in late August 2008 from the exhaust maniford to tailpipe.
Navigator pictures by dtl504 - Photobucket
I am lost! could the catalyst convertor be bad? I do not have any leaks in the exhaust system....Puzzle......
Old Mar 5, 2010 | 07:03 AM
projectSHO89's Avatar
projectSHO89
P0430 is NOT caused by O2 sensors! The code doesn't indicate a bad sensor, it indicates the sensor is showing that the converter is not working.
You likely have a bad converter on that side.
Old Mar 5, 2010 | 10:21 AM
alloro's Avatar
alloro
Although I agree with your diagnosis, I am equally wondering why a 1-1/2 year old catalytic converter would be bad already?
Old Mar 5, 2010 | 07:34 PM
projectSHO89
It's a MagnaFlow...
I learned a really loooonnnnng time ago (the hard way) - just because something is new(er), doesn't mean it's good. Always assume it can be anything and follow the data.
Assuming it's not a manufacturing defect, the most common reason for premature cat failure is due to excessive unburned fuel getting dumped into it for an extended time. A misfire, vacuum leak, or a faulty O2 sensor (either of which should have previously tripped a MIL) are the more common reasons.
Old Mar 6, 2010 | 01:19 PM
Modified 99's Avatar
Modified 99
It's a MagnaFlow...
Just curious, how would a vacuum leak put unburned fuel into the cat. It would seem to me that a vacuum leak would LEAN the fuel.
Old Mar 6, 2010 | 02:57 PM
alloro's Avatar
alloro
It does, but in response the PCM richens the mixture.
Old Mar 6, 2010 | 03:06 PM
Jigger2020's Avatar
Jigger2020
I had some welding done on my exhaust system & soon after the code came on for all 4 sensors,after fooling around for days I found a blown fuse in the fuse box under the hood,that was the problem,Gigger
smcox1
62
Feb 19, 2017 08:01 AM
attn2dtl
Jan 29, 2015 12:28 PM
5 Star Tuning
Vendor Specials, Discounts, Product Announcements & Group Buys
Sep 17, 2012 04:48 PM
DTL504
Dec 24, 2011 10:08 PM
DTL504
18
Jan 21, 2009 06:01 AM
