Steering box leaking
Old Mar 20, 2014 | 02:32 PM
PStruwing's Avatar
PStruwing
Hi All
I just did a big road trip From Central Ontario down to Orlando Florida for March Break and had 7 people in the van plus all the crap that goes with them.
All was good till I found a puddle of steering fluid under the van coming from the steering box output arm. Not sure if I hit something or what caused it.
I am going to throw new seals in but need to know does my 97 E-150 have a axle rating above or below 4200 lbs. I am assuming under...
Has anyone else done this repair? I did it last on a 71 Pontiac, many years ago.
Cheers
Old Mar 21, 2014 | 05:21 AM
JWA's Avatar
JWA
Just a few months ago my steering gear box developed a leak where the Pitman arm shaft exits the case. To my knowledge there's no seal kit available for the box. I could be wrong but conversation with several trusted mechanics led me to just replacing it.
Your E150 front axle should be under 4200#, the drivers door sticker will confirm that though.
I opted for the Ford reman'd unit, $258 plus $225 core. Needless to say that core was returned ASAP!
Apart from a Redhead Steering Gear unit locally I could only find "cheap" reman'd units, most by the Cardone A1 brand---not one I'd trust even though those are about $100 less.
Old Mar 21, 2014 | 06:14 AM
PStruwing's Avatar
PStruwing
Here is the seal kit! $19.16
More Information for EDELMANN 8771
I will order and wait till the weather breaks here, still below freezing for another week.
Old Mar 22, 2014 | 05:05 AM
JWA's Avatar
JWA
That's interesting---and very affordable too. In my case replacing the box seemed less involved than rebuilding it so just swapped in the new one.
Apart from the extra labor and assuming no internal parts are as worn as the leaking seal this might be a great alternative with a cost savings advantage.
If you dig into this and care to document it with photos and text it might make a great addition the our knowledge base here.
Thanks for sharing!
Old Mar 22, 2014 | 07:19 AM
PStruwing's Avatar
PStruwing
That was the game plan for this weekend, but the Heavy Snow fall warning kinda put a stop to the plans.
Dweber85rc
Jun 13, 2019 01:32 PM
lonnie
Apr 17, 2008 09:17 PM
Stroked Out!
Feb 13, 2007 08:45 PM
carpe_diem
Jan 21, 2004 11:10 PM
geo_bar
Apr 12, 2003 08:57 PM
