Got a '87 (truck) 302 in my '50 F1 pickup....Question: Would a set of Flowtek headers listed as being for a " 69-79 Ford F100 302".....bolt onto my block ok?
Don't think there will be clearance issues otherwise. If there happened to be on the steering shaft, I would just cut/reroute and reweld anyway.
Any 302 headers will bolt on any 302 motor, vehicle clearance is the only concern.
Thanks very much Conan....I thought that was the case but being a Chevy guy (I've seen the light now) for so long I just don't know alot of stuff about Ford engines and wanted to ask one of you "gurus" on here who does.
Thanks again...this is a wealth-of-knowledge forum. Mighty glad I joined.
A lot of headers come real close to the starter motor. This has caused early starter failures. I think one of mine comes close enough to one of the terminals that I had to wrap duct tape covered with foil around it to prevent it from touching. You can avoid this problem with one of those compact PM starters.
Welcome to the land of front of engine distributors. Share some pics of your ride when you get a chance.
