General Diesel Discussion
Gasoline blew engine
Old Mar 18, 2014 | 10:29 PM
Brewmaster's Avatar
Brewmaster
2008 F450 with 6.4 litre. I filled the tank with gasoline by mistake and drove it home. (10 klicks). The next morning it started like crap and I realized what I had done. Towed it my mechanic who claims there is no compression in 2 cylinders. Apparently I have to remove the cab in order to pull the engine?!
a) Is it possible to lose compression due to gasoline?
b) is it really a $6,000+ job to pull the power plant?
c) if a and b are true - does anybody want to buy a truck with no compression on 2 cylinders?
Old Mar 22, 2014 | 07:28 AM
AlaskanF350's Avatar
AlaskanF350
Need to give more info on yer vehicle...
So the experts here can help...
Chris
Me, I'm no expert... but I drive a 6.0
Old Mar 22, 2014 | 03:03 PM
Brewmaster's Avatar
Brewmaster
Not sure what more you need. 6.4 diesel 2008.
Chris
Old Mar 22, 2014 | 04:33 PM
m-chan68's Avatar
m-chan68
If you've gassed up your engine and ran it 'till it began to run the way you describe, EVERYTHING in the high pressure fuel system requires replacement, as well as all low pressure fuel system components flushed of all residual gasoline. This means your HPFP, all eight injectors, all high pressure fuel system plumbing will need replacement.
How has your mechanic determined you have no compression in two cylinders? Has he run only a relative compression test using only a scan tool, or has he actually run a manual compression test which reads actual individual cylinder compression psi readings?
For what it's worth, I just happen to have a 2008 F-550 6.4L in my bay right now that I just replaced the engine with a complete Ford drop-in unit back in January. Only 118 kms. and 15 hours later, it arrived back on the hook last week with a badly leaking HPFP, leaking fuel internally into the crankcase that caused the engine to run away. Three consecutive relative compression tests via my IDS scan tool indicated issues with cylinders #1 and #3. However, before Ford would authorize a service replacement unit, I was requested to take manual compression readings on all eight cylinders which immediately revealed cylinder #1 100 psi lower than the other seven. The point being, a manual test will yield much more accurate results before you make your decision.
In any event, replacing the high pressure fuel system components alone, is not going to be a cheap affair either.
Old Mar 22, 2014 | 09:58 PM
Monty Simmons's Avatar
Monty Simmons
consider this.
If one purchases bad fuel and such fuel causes damage to your truck and one has comprehensive insurance coverage, many times such insurance will cover the damage.
If a gas station puts gasoline in the diesel tank and you used the right pump with the wrong fuel thereby getting gasoline instead of diesel your insurance would likely cover the damage.
Now, I do not know if one's insurance will pay if one pumps the wrong fuel by accident but such seems to be an "accident" just like running the truck into something and killing the engine.
Might be worth it to check with your insurance to see.
Also, one can put rebuilt 6.0 engine for about $7,000.
http://www.ashevilleengine.com/default.html
Old Apr 18, 2014 | 11:08 PM
parkland's Avatar
parkland
How much?
What exact kind of truck?
therigwelder
Dec 30, 2016 08:56 AM
SKaero
Aerostar
Aug 16, 2016 11:59 AM
rdw516
Mar 5, 2007 03:07 PM
only210Kmiles
15
Aug 21, 2003 05:16 PM
ghak
19
Apr 6, 2003 12:46 AM
