Motorcraft or Auto store/China fuel filter?
Old 03-18-2014, 03:01 PM
Robby Nash's Avatar
Robby Nash
Robby Nash is offline
My truck is 04 F250 6.0. Ok so the Motorcraft filters are $60 for the frame and upper engine. Is it ok to use an auto parts store filter? I know everyone on here is OEM everything which I do on almost everything on my truck. But darn them Motorcraft filters are high dollar. Any concerns with the cheap $20 ones that seem to look the same?? If not where is a cheap web page with Motorcraft that is the best price.
Old 03-18-2014, 03:02 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
no--OEM only
think about it--you only have to change the fuel filters every 10k or 15k miles--the price per mile is very minimal and will keep you from having issues with the engine.
Old 03-18-2014, 03:04 PM
Robby Nash's Avatar
Robby Nash
Yea I know that's true. Anyone online have a better price then $60 for the two?
Old 03-18-2014, 03:09 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Order at Advanced Auto with online coupon for in store pick up and you'll get a set of Motorcraft filters for about $35
Josh
Old 03-18-2014, 03:14 PM
Robby Nash's Avatar
Robby Nash
Josh
Wow that is great info Thanks!
Old 03-18-2014, 03:18 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Old 03-18-2014, 03:19 PM
rjglenn's Avatar
rjglenn
rjglenn is offline
A good code for advance autoparts is TRT30. This will give you 30% off up to $50 saved. You look them up and pay online, print out your receipt and then cruise to the store and pick them up. If you need to spend more than $150, break it up into mulitple orders to maximize your savings.
Old 03-18-2014, 03:48 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Thanks for that info--good to know!!!
Old 03-18-2014, 03:56 PM
Robby Nash's Avatar
Robby Nash
I just ordered at Advance with code TRT25 and it takes $20 off. Was $55.99 now $35.99. Going to pick up in store. Way better than $60+ at the Ford house.
Old 03-18-2014, 04:04 PM
Robby Nash's Avatar
Robby Nash
Oh since we are on the subject of being cheap. I found that Walmart has the 5 quart Motorcraft oil 15w 40 for $17.23, FYI.
Old 03-18-2014, 05:26 PM
Forddiesel06's Avatar
Forddiesel06
Forddiesel06 is offline
Only OEM filters unless u have a deep wallet for unnecessary repairs. Just saying
Old 03-18-2014, 05:41 PM
05F250DSL's Avatar
05F250DSL
05F250DSL is offline
Set them side by side the lower filter in the frame is a different shape between oem and aftermarket. On the aftermarket there is a lip and oring missing flat not there. Plus the oem has another layer wrapped around it that is supose to repel water from going thru. $60 bucks for 8-10k miles really is not expensive.
Old 03-18-2014, 05:46 PM
05F250DSL's Avatar
05F250DSL
Meijer has rotella T6 for under $22 regular price
Old 03-18-2014, 06:35 PM
amill's Avatar
amill
amill is offline
Menards has T6 for 21.36/gal. regular price. last time I got it there was 2$/gal rebate from Shell and 11% rebate from Menards, limit 2. saved a little $
Old 03-18-2014, 07:22 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
There have been many threads about problems with non original equipment filters. From injectors to fuel pump problems. Purchase my filters from a local IH truck dealer for a better price than ford. As ford buys from IH. Same racor#s inside the box.
These engines are very sensitive to fuel pressure and volume so don't please go cheap as it could cost a lot more in the future.
Quick Reply: Motorcraft or Auto store/China fuel filter?
