coolant overflowing
Old Mar 18, 2014 | 11:34 AM
63ferd's Avatar
63ferd
coolant overflowing
I have a 1996 f250 powerstoke. I have coolant overflowing out of the de-gas bottle under the cap. I have replaced the cap and did not fix it.. it leaks about 1-2 gallons only when warm. Do I have bad injector cups or ???? Any help would be great!!!!
Old Mar 18, 2014 | 12:03 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
If it smells like diesel, bad injector sleeves.
If the liquid that runs out of the bottle and under the truck has a pretty rainbow tint to it, bad injector sleeves.
If it spews out coolant when warm, and is visibly lower in volume when cold, I'd say bad head gasket or something. If level stays up all the time AND overflows, I'd say bad sleeves.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Mar 18, 2014 | 12:23 PM
63ferd's Avatar
63ferd
Yes it is a lot lower when cold. Abd the heat Only works when I add coolant but then it all pisses out. Is the injector sleeve the same as an injector cup??? If not what is it?? Sorry Im new to powerstrokes. It only has 190,000miles
Old Mar 18, 2014 | 12:42 PM
63ferd's Avatar
63ferd
Old Mar 18, 2014 | 04:51 PM
fordpride's Avatar
fordpride
Injector cup/sleeve is the same.
I'd start with pressure testing the coolant system
fordpride's Avatar
fordpride
Does it run hot ?
Old Mar 18, 2014 | 04:52 PM
63ferd's Avatar
63ferd
It gets gets around A in normal then drops to the N. And bounces around like that
Old Mar 19, 2014 | 06:06 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Then you may have a t-stat issue. It sounds like it gets too hot and boils out some coolant.
I'd get a new t-stat from Ford (skip the parts store crap) and see if that helps.
Drop the old one in a pot of hot water on your stove with a thermometer in it and watch what it does at what temp.
__________________
Old Mar 19, 2014 | 07:19 AM
63ferd's Avatar
63ferd
Ok!!!! Ill get back to you guys
ExPACamper
Jul 4, 2015 09:36 AM
Jerry Chaney
May 22, 2014 07:50 AM
Kdr358
32
May 26, 2013 12:43 PM
Brett W 55 Ford
Nov 20, 2010 11:08 PM
beer boy
Feb 28, 2009 04:33 PM
