Overheating coil?
Old Mar 18, 2014 | 11:54 AM
  #31
Dave145's Avatar
Dave145
Okay good to know. I will check into this when it acts up again.
Old Mar 18, 2014 | 01:01 PM
  #32
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Originally Posted by Jklnhyd
FMC400 is gonna kick your....
Imma go hangout in another thread before he gets back, lol.
Originally Posted by turbohunter
That is hIlarious.
Yes it is, almost as funny as this.
You restarted it, rather than do the tests that you were given?
Go back to the store.
Take your multimeter....
I am trying to capture all the troubleshooting steps into one write up for my TS notes....keep'm coming. And thanks to all and fmc 400 keeping us on track.
Old Mar 18, 2014 | 01:08 PM
  #33
turbohunter's Avatar
turbohunter
Funny stuff Rich.
I hope fmc knows that we are laughing out of respect and jealousy of the way his mind works and the knowledge he possesses.
I have to stick my finger in the socket before I figure it out.
Old Mar 18, 2014 | 02:15 PM
  #34
77&79F250's Avatar
77&79F250
At least its just a finger.....lol
Old Mar 18, 2014 | 02:42 PM
  #35
fmc400's Avatar
fmc400
MSEE
Haha, thanks all for the kind words
Old Mar 18, 2014 | 02:45 PM
  #36
Dave145's Avatar
Dave145
Okay I just performed the sceond test...the light DOES blink while cranking the engine...not sure if I should be happy about that or not...
Old Mar 18, 2014 | 03:53 PM
  #37
fmc400's Avatar
fmc400
MSEE
That means the module is firing the coil properly and takes power, the ignition module, and pickup module out of the equation.
Assuming this behavior is reproducible, the issue is isolated to the secondary side of the ignition system - distributor cap, rotor, or plug wires. Perhaps the rotor isn't riding the inside of the cap, or the coil wire is bad. The other possibility is that you really do have spark and you're not checking properly, and the engine is shutting off for some other reason. You might want to repeat this a couple more times to make sure the test results are the same in the presence of the failure mechanism.
Old Mar 18, 2014 | 04:03 PM
  #38
turbohunter
I keep thinking about the low voltage.
Dave you say the coil and wires are new.
I'd keep checking upstream, if all the connections are good.
Old Mar 18, 2014 | 04:11 PM
  #39
Jklnhyd's Avatar
Jklnhyd
I always look at a fixit thread for someone down the road too. Someone 3 years from now will be able to read this through, and be able to NOT go through the same steps that Dave has, saving them even more time and frustration.
And hopefully they can see the good natured humor also
Old Mar 18, 2014 | 04:13 PM
  #40
turbohunter
Yeah thats kinda why I'm jumping in.
Just to keep learning.
Though sometimes in an effort to be helpful you screw up the natural progression of steps.
Hope that's not the case.
Old Mar 18, 2014 | 04:16 PM
  #41
Dave145's Avatar
Dave145
Yes the coil I have in there now is ~4 months old. The plug wires I literally put on on sunday. The distubuotr cap is also ~4 months old, as is the rotor.
I will continue to check with the test light when the truck dies again.
What I don't understand is that if the coil and primary side of the ignition system is working fine (at least at this time), then why is the voltage from ground to the + side of the coil so low?
Old Mar 18, 2014 | 04:19 PM
  #42
turbohunter
Go back to the first page of your thread, fmc listed a few things it might be.
Edit
I just checked also, he asked if the coils were the right ones.
Old Mar 18, 2014 | 04:22 PM
  #43
Dave145's Avatar
Dave145
also for what it's worth, I bought this truck with this issue. It's survived 2 engines, 2 distributors, countless plug wire sets and spark plugs, 4 ICM's, 3 or 4 coils, etc. It's just becoming more of a predominant issue and it's acting up ALOT more often thatn it always did...which is why its time to finally fix it right
Old Mar 18, 2014 | 04:25 PM
  #44
Dave145's Avatar
Dave145
Right I understand that. But from my understanding (and I may be way skewed on this), everything listed there is for the primary side of the ignition which is reportedly working fine at this time...
Old Mar 18, 2014 | 04:32 PM
  #45
turbohunter
Oh yeah. Duh.
So why such low voltage.
Think I'll just eat my popcorn and watch the movie.
