Guys I am looking for a mig welder. I will be welding some frames, body work and other mostly automotive items. It will be used in my home shop. I am familiar with Miller and Hobart and have used both. Anyone have any info on Clarke. They have a 180 that comes with everything...cart , helmet, gloves , gas gauges etc for less than a Miller 175 or Hobart 175. Any suggestions would be helpful..Thx
I've never heard of Clark welders, but for my money, I'd go with a brand name and you just named the best two. I've got both. A Hobart handler 100 amp 'suitcase' welder and at Millermatic 200.
The little machine does a great job on sheet metal and up to 11 guage. but when you're doing frame work... say 1/8 or 3/16 and up it doesn't have the heat you need... that's why I bought the 200.. it will give you better penetration and longer duty cycle...
the main consideration is part availability... on a saturday afternoon can you run to the welding supply store and get parts for the Clark ?? If you jam up your last tip you can pick up a miller or hobart at Home Depot or Lowes on Sunday... something that needs to be considered... the extras they offer are cheap enough to buy alone... consider what you're getting in features for the price...not the extras...
just my .02¢
john
two good sites you might want to visit for good welder info
I would stay away from the Clark. Customer support is near nothing, and parts are hard to get. Stick with the big three. Lincoln, Miller, or Hobart. My preference being the Lincoln. (BTW, Miller and Hobart are owned by the same parent company.) The Lincoln has had enough good common sense to not add wire speed tracking to their machines like the other two have. That will screw up a weld quicker than anything. The people at Hobart have been asked to do away with WST, but they are still doing it. Let us know what you do.
PS, The Lincoln SP175+ is the one you should be looking at. They are not sold at Home Depot, etc. Go to a welding supplier and check them out.
Thanks for the info guys. I have found a Hobart 175 with cart for 580 and a Miller 175 with cart and extra wire for 660. The lincoln is about another 100 bucks. A toss up I suppose....
I bought my hobart from this guy on ebay http://www.stores.ebay.com/id=20436331&ssPageName=L2
Very professional and fast delivery. He sells the big three for good prices. About 100 less then I could get locally.
I had a lincoln stick welder and a miller mig welder, when I started building my drag car a few years back, I had to buy a TIG welder (chrome-moly tubing) and since then, I have sold both my stick and my mig. The Miller Econo-Tig is really the way to GO.
You can weld folding lawn chairs back together, and you can weld up to 3/8" think plate steel with the same machine! You have to use Argon for a shielding gas but you can weld just about any kind of metal, I have welded cast iron heads, aluminum heads, sheet aluminum and steel body panels.
It's not as fast as a mig and won't put up with any kind of crap on your work like a stick, the metal has to be absolutely spotless! But the welds are prettier and stronger than anything else, bar none.
Best thing is that since there's no wire feed, there are a lot less moving parts, there is absolutely NO SPLATTER whatsoever, if you get one with a foot control like mine, you wild with your foot on the "gas pedal" and you can move the amperage up or down like an accelerator. This is really handy if you have an inconsistant gap to weld up.
Originally posted by Bobby Reynolds I had a lincoln stick welder and a miller mig welder, when I started building my drag car a few years back, I had to buy a TIG welder (chrome-moly tubing) and since then, I have sold both my stick and my mig. The Miller Econo-Tig is really the way to GO.
Try one, you won't be sorry!
Tig kicks butt, but requires "thought".
I don't trust myself so I just use the MIG gun. "almost" idiot-proof.
-T
I have a Lincoln 175 Mig unit and I like it, I also have an engine drive Miller AE200-LD, which I also like for stick welding. I am wondering if anybody knows of an engine driven (preferrably diesel) unit that will do MIG, TIG and stick? If it also generates electricity that would also be a plus. I'd like to sell my existing equipment including a 10KW generator and have one unit to do it all! My garage is getting full!
