VIN Code for Custom Cab?
Old Mar 16, 2014 | 05:39 PM
Mercmeister's Avatar
Mercmeister
Hi -
I deciphered my VIN and have a dumb question: How can you tell from the VIN if the truck is a real "Custom Cab"? Here is what I have:
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]-->F10 = F100 2wd Truck
Y = 352 CID, 8 Cylinder, 2V Carburetor
K = Kansas City Assembly Plant
748031 = Assembled September, 1965
129 = Wheelbase in Inches
HM = Light Beige and White (Two-Tone)
F100 = 2wd F100, 5000 GVW
D = Beige Woven Plastic and Beige Vinyl
81 = Conventional Cab
G = Ford C-4 Automatic Transmission
C1 = Spicer (Dana) #44 Rear Axle /3.30:1 Limited Slip/ 3300 lb. Rear Axle Capacity
5000 = GVW
172 = Net Certified Horsepower @
4000 = RPM
54 = Omaha District Sales Office (where dealership would have ordered vehicle from)
6783 = Special Order Number (complete order number = 546783)
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]-->
Thank You,
Dan M.
Old Mar 17, 2014 | 12:52 AM
SuperSabre's Avatar
SuperSabre
Did you do your decode using the first section of the 1966 factory Workshop Manual? The reason I ask is that you are showing Transmission "G" as a C-4 automatic mated to your 352 FE - which is what the workshop manual would lead you to believe. In 1966 the automatic hooked to the FE was a Cruise-O-Matic. The C-4 was only used on the 6 cylinders in '66, according to what I'm pretty sure Number Dummy told me a long while ago. To answer your question, you need the '64 - '72 Parts and Accessories manual to decode Custom Cab (81B) or Standard Cab (81A). It will also give you the "official" description of your D81 interior: Medium Beige Crush Vinyl and Light Beige Cody Pattern in a Custom Cab. Hope this helps.
Old Mar 17, 2014 | 01:03 AM
The Masked Rider's Avatar
The Masked Rider
My 65' cc has the 'G' code trans which is the cruise-0-matic and its behind the 352. Wellllll, it was when it was new.
Old Mar 17, 2014 | 01:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Mercmeister
I deciphered my VIN and have a dumb question: How can you tell from the VIN if the truck is a real "Custom Cab?"
VIN: F10YK748031
F10 = F100 2WD
Y = 352 2V
K = Kansas City MO Assembly Plant
748031 = 1966 .. assembled September 1965.
COLOR HM: H = Sahara Beige / M = Wimbledon White
BODY D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
TRANS G = MX Cruise-O-Matic
AXLE C1 = Spicer (Dana) 44 Rear Axle / 3.31-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
VIN does not contain a code for the type of cab, it's determined by the BODY code stamped on the Warranty Plate.
Two shades of white were used 1964/66. C = Pure White.
1961/78 trucks: FoMoCo used the G code for all A/T's. One had to know which A/T was available with what engine.
C4 was not used with FE engines. MX Cruise-O-Matic: 1965/67 F100/350 352 & 1965/72 F350 300 I-6.
Old Mar 17, 2014 | 06:25 PM
Mercmeister
Thanks! Yes, I was decoding using the Ford truck shop manual. I thought it was strange to have a C-4 behind a 352 FE. My truck has a C-6 in it now.
Thanks You,
Dan M.
3Bushwackers
Apr 29, 2020 04:52 PM
HAMS64
Aug 15, 2019 12:12 PM
Fjcaldwell
Jun 26, 2017 11:32 PM
CajunChris
18
Jan 15, 2014 07:55 PM
F&M
Jul 23, 2013 04:38 PM
