IDM issue... I Think???
Hi all. A while ago I posted a issue with my 95 7.3...
Hears the story again.... Truck was running fine then I had a stall at a light. Started up and went home. In the morning I went out to start and it barely started sounded like it was only running on 6 or 7 cyl.. Limped it to the shop. Hooked up my AE and did a injector buzz test. Got a fault on the 6 & 8 bank. Pulled valve cover and saw a burnt pin on a glow plug for #6. Figured it was taking out 6 and 8 injectors.
Got a aftermarket gasket with the built in injector harnesses and two new pig tails. Installed them and tried to start... Not a thing Hmmm.
Hooked up AE and attempted to do another buzz test. Nothing buzzed...
It seems to me im not getting any action from the IDM
Im kinda stumped Any suggestions would be great Thanks in Advance
https://www.ford-trucks.com/forums/1...harness-2.html
This is the link to a previous post that shows wiring diagram
haha the 6, 8 pigtail was replaced befor I bought the truck and the 2, 4 pitail I cut off wires tight to plug so I had some wire to work with
Im sure I got the 2, 4 pigtail correct.....Maybe screwed up the 6, 8....
If I did get a wire crossed, would that stop a buzz test?? I did disconnect each plug and tried a buz test wit one plug disconnected and nothing happened... No Buzz
If you only worked on the driver's side, the passenger side would still buzz regardless if you messed up the driver's side pigtails.
Swapping in a spare IDM, or borrowing a buddy's IDM to try will certainly help narrow it down and only takes a few minutes.
An IDM from any year truck from '94.5 - '03 will work.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Pins E D C B A
Cylinder 2 - 4
E = Brn
D = Wht
C = Pnk/Yel
B = Brn/LtBlu
A = Brn
Cylinder 6 - 8
E = Brn
D = LtGrn/Org
C = Pnk/Yel
B = LtBlu
A = Brn
I think it could depending on what is crossed. The high side (120 volts) is shared by all injectors (center pin) so if the IDM saw a short it would try to protect itself. Try unplugging both drivers side connectors and re-do buzz test.
