IDM issue... I Think???
Old Apr 22, 2014 | 10:34 PM
fluidp's Avatar
fluidp
Hi all. A while ago I posted a issue with my 95 7.3...
Hears the story again.... Truck was running fine then I had a stall at a light. Started up and went home. In the morning I went out to start and it barely started sounded like it was only running on 6 or 7 cyl.. Limped it to the shop. Hooked up my AE and did a injector buzz test. Got a fault on the 6 & 8 bank. Pulled valve cover and saw a burnt pin on a glow plug for #6. Figured it was taking out 6 and 8 injectors.
Got a aftermarket gasket with the built in injector harnesses and two new pig tails. Installed them and tried to start... Not a thing Hmmm.
Hooked up AE and attempted to do another buzz test. Nothing buzzed...
It seems to me im not getting any action from the IDM
Im kinda stumped Any suggestions would be great Thanks in Advance
Old Apr 22, 2014 | 10:38 PM
ReBilld's Avatar
ReBilld
Double check the wiring on the pigtails. They are easy to get a wire crossed. Have you unbolted the IDM and given it the shake test yet to see if there is water in it?
Old Apr 22, 2014 | 10:59 PM
fluidp's Avatar
fluidp
No Shake test yet. I will yank it off tomorrow. I hope I got the wires correct, the colors on the new pigtails were a bit different from the harness. Does anyone know the colors for the oem harness for injector plugs 2, 4, 6, & 8 ??
Old Apr 22, 2014 | 11:05 PM
ReBilld's Avatar
ReBilld
There was a wiring diagram of that floating around on here a while back. I can't remember who posted it though.
Old Apr 22, 2014 | 11:20 PM
fluidp's Avatar
fluidp
https://www.ford-trucks.com/forums/1...harness-2.html
This is the link to a previous post that shows wiring diagram
Old Apr 22, 2014 | 11:30 PM
ReBilld's Avatar
ReBilld
You still have the old pigtails you cut off? Should be able to look at those if you still have them.
Old Apr 23, 2014 | 12:01 AM
fluidp's Avatar
fluidp
haha the 6, 8 pigtail was replaced befor I bought the truck and the 2, 4 pitail I cut off wires tight to plug so I had some wire to work with
Im sure I got the 2, 4 pigtail correct.....Maybe screwed up the 6, 8....
If I did get a wire crossed, would that stop a buzz test?? I did disconnect each plug and tried a buz test wit one plug disconnected and nothing happened... No Buzz
Old Apr 23, 2014 | 06:39 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
If you only worked on the driver's side, the passenger side would still buzz regardless if you messed up the driver's side pigtails.
Swapping in a spare IDM, or borrowing a buddy's IDM to try will certainly help narrow it down and only takes a few minutes.
An IDM from any year truck from '94.5 - '03 will work.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 23, 2014 | 07:52 AM
madpogue's Avatar
madpogue
Go by position rather than (or along with) insulation color. Front to back, it's #6 GP, #6 injector, common, #8 injector, #8 GP.
Does AE at least communicate? Can it scan for codes?
Old Apr 23, 2014 | 10:39 AM
fluidp's Avatar
fluidp
Yes my AE communicates just fine.
I just replaced pigtails on drivers side.
I will try to find another IDM and give that a try
Thanks
Old Apr 23, 2014 | 10:42 AM
Hussler's Avatar
Hussler
This is the info I have ...
Pins E D C B A
Cylinder 2 - 4
E = Brn
D = Wht
C = Pnk/Yel
B = Brn/LtBlu
A = Brn
Cylinder 6 - 8
E = Brn
D = LtGrn/Org
C = Pnk/Yel
B = LtBlu
A = Brn
I think it could depending on what is crossed. The high side (120 volts) is shared by all injectors (center pin) so if the IDM saw a short it would try to protect itself. Try unplugging both drivers side connectors and re-do buzz test.
Old Apr 23, 2014 | 11:57 AM
fluidp's Avatar
fluidp
Hi, Thanks for the info..
I have tried buzz test with 2,4 &6,8 unplugged and nothing
Old Apr 23, 2014 | 12:30 PM
Hussler's Avatar
Hussler
If not already done check the IDM Maxi fuse #8, 30 AMP.
Old Apr 23, 2014 | 12:32 PM
fluidp's Avatar
fluidp
ok thanks
Old Apr 23, 2014 | 01:19 PM
fluidp's Avatar
fluidp
OK #8 maxi fuse is good
IDM shake seems good....it looks sealed up still
Is it hard to open up?? Looks like the edges are crimped to keep it closed. I was thinking about opening and see if there r any burnt things inside??
