Rim question for 2014 F250 supercab
What's the smallest size rim I can run on a 2014 F250 XLT supercab?
Planning to run 35" tires, and I like more size wall. I currently have 18" rims, but wanted to go down to 17 or even 16 if they will fit.
Also, if I stay with 18" rims, how much rubbing will I get if I run 35x12.50x18 on the OEM rims?
Pretty sure 17 inch will still fit. 16's have not fitted since they went to coil springs in the front (2006?). Can't answer your question about tires, it will depend on the offset on the rims. Check tirerack.com for more info. Whatever tire you pick , make sure you get the correct load range, probably E for your truck.
