That's being pretty bold "I'm gonna run it anyways" You have a big 4x4 truck, it's not a great cam for a truck. Yeah you can find plenty of trucks running mustang cams, you can find trucks running bigger cams as well. Still doesn't change the fact that the e303 is a cam for a 3500 lb car, not a 5500-6000 pound truck.
As far as what injectors, if you're only going to run gt40 heads, you only need 24lb injectors. Even if you did a stroker kit.
If you are smoking some good stuff, and think you're going to persue forced induction, you'll need 42s. But before any of that stuff, you'll need mass air and a programmable chip like quarterhorse or tweecer.
You don't "need" a fuel pressure regulator. It can help sometimes, my 460 loves extra pressure. But you gotta test it and log the air fuel ratio.
You don't need bigger fuel rails til you're above 450-500 hp.
Well i bought the cam brand new for my 68 but now i am not going to use it since i plan on doing a coyote motor swap in it. I have the mass air stuff already the mass air is not a problem. already talk to local speed shop about custom tunning Ecm
The new 5liter is only $7k. I was surprised. If I had the cash, and didn't have a 400hp sbf in my 68 already, I'd opt for the new tech. But I just bought rack kit, keisler t45, hyd clutch kit, and all kinds of crap. Oh well.
Anyway, I'd still keep the e303 on the shelf for another project. I think it will work ok, but not the way you need or want in a vehicle that's 2000lbs heavier and with less effective gear ratio than what is normally in a mustang with that cam.
Your project though. I didn't listen to people when I twin turbod a 351 with a z303 cam... Let's just say it was awesome, but you had to mess with so much to get it to work nice.
What is the tuning place going to do. Dyno and custom sct chip or what. I'm interested because I'm looking at quarterhorse for my truck and would sometimes just like someone else to tune my vehicle just once. Everything I tune is a toy. I can handle the quirks. But I'd like some fine tuning help for my daily driver.
yes i agree on the new coyote motor tell me more about your twin turbo setup? the specs on that z303 are more lift that the e303
As for the tuning i dont know what he has for plans he said get it done and he would tune it he runs a great speed shop DBR high performance
Z303 is also called "camzilla". It's significantly bigger/different than the e303. I don't know the specs off hand, but It's probably the biggest oldschool cam you can use in an efi car. It run like crap on eec4 so I put megasquirt on it. Turbos were two holset h1c. The cam alone was crazy fun, but boost made it a flamethrower with the overlap and stuff. Was fun while it lasted.
Nope.. sorry that is completely false. A single 75mm TB has almost the exact same total volume as the stock twin 52mm throttlebodies, and although the GT40 intake flows better than the stock 5.8 intake the stock heads on this motor are the big limiting factor so these intake parts alone won't make much difference in power positive or negative.
I can tell you that I have experienced this first hand, so no it was not false in my case by any means. Not sure if you experienced this or are going by theory on this one, but for me I know this to be the case.
Can you elaborate a little more. I reread most of this and I still am in the dark a little. Conanski said the heads will limit performance after you put a better intake, no matter what tb you put on it.
One thing I like about the twin tb is you don't get that hesitation from the big tb throttle tip-in. With stock ecu and no tuning it sometimes was noticeable.
Chase, I would not use the GT40 heads. The BEST bang for the buck is a set of aftermarket heads. Either Trick Flow, Ford Racing or a set of AFR would be your best bet.
Also a STOCK 5.0 roller cam from a mustang really wakes these engines up
I am doing exactly this when I tear into my engine to fix the head gaskets
Brad, we were talking about the ho roller cam earlier. There are better cams on the market for doing what you want, granted they cost more than the 25$ you can get an ho cam for, or just get when you buy an engine to rebuild. But with you using boost, the stock ho cam will be a good performer.
While it is an upgrade, there are better cams out there to better fill the needs of a truck engine. (Are you doing this to the lightning or the bronco)
We aren't derailing the thread, we talked about cam choice earlier.
I know the ho cam is used a lot.. With positive results. I'm just saying there are better ones on the market for doing what you want in a truck.
I should cut my times from 14.74 in the 1/4 to the Low 13s
Brad I appreciate it but I already purchased the heads $300 as well as the front axle for $300 I am going to run the 5.0 cam, gt 40 heads,lightning intake the cab I bought is even a factory lightning cab.
Yeah. $300 is cheap to $1300. I see your point
Too bad you didn't get the seat too. Title come with it? I see it is a 93 cab
