Modular V10 (6.8l)
Need a source
Old Mar 14, 2014 | 11:11 PM
wigpro's Avatar
wigpro
Need a source
Went to lower my spare and realized that I am missing the folding long jack handle and key for the spare lowering mechanism...
I checked E-Bay and nothing reasonable - one complete kit with the jack and everything....but have the lug wrench and jack, just missing the long handle??
Today I ordered new rear axle U-Bolts so I can remove the 4 inch lift so I can tow my fifth wheel also new stock rear front leaf spring shackle to remove the front lift as well...but before my travels begin, need to find a jack handle, any ideas, let me know....
Thanks
Jim
Old Mar 15, 2014 | 08:16 AM
pappy19's Avatar
pappy19
Junk yard is the best place. You might also consider getting a 3/4 -1 ton sizzor jack that is made for Chevy pickups. It's alot better setup than the bottle jack from Ford. I got mine at a junk yard also.
Old Mar 15, 2014 | 09:22 PM
IslandBlueV10's Avatar
IslandBlueV10
Yeah best bet is a junk yard. As for the lock use a 9/16 socket and some extentions, tap it on and lower your spare tire. Then take the plastic tube twist it and remove it, then take a screw driver or pliers and remove the lock. After that you will just use the normal jack rod.
ufvj217
Dec 28, 2015 02:41 PM
SC_Hoaty
Oct 29, 2012 04:01 PM
stu37d
Jul 21, 2012 05:04 PM
nrskel78
Nov 16, 2011 03:56 PM
nlindelldc
15
Jan 13, 2009 06:57 PM
