My second and third baptism
Old Mar 14, 2014 | 07:23 PM
jmtbiggin's Avatar
jmtbiggin
Well the first baptism was me proclaiming my faith in my Savoir,Jesus.The second was a hair more entertaining. I am a long time member,short time poster.always got PM on previous truck done at Ford. In trying to save a dime and educate my self I am doing it my self this go round. I have put in time in the 6.0 tech folder,and am on page 156 of 6.0 forums.The tech folder is very informative and I thank all contributers.As taker i am grateful. First stop was oil change.5w40 full synthetic,motorcraft filter per tech folder. Next time i will go under the truck with more than 2.5gal jug,not so fresh feeling laying in oil.Note to self, 2 2.5 g buckets. No worries cause diesel fuel rinsed me right off. Got new HFCM,updated plug and motorcraft fuel filter in as well.So then i carefully reach inside truck and cycle ign.She fires right up.At the urging of most in this forum i. Also had a scangauge2 to program. But a shower and change of clothes was first.Programming was slow but i peckedAway.
Old Mar 14, 2014 | 07:43 PM
Mr.Nobody's Avatar
Mr.Nobody
Ha ha, that is funny. Sorry for laughing at your expense, but I was shocked by the amount of oil that came out of the engine the first time I pulled the plug.
Old Mar 14, 2014 | 08:06 PM
run6.0run's Avatar
run6.0run
Well crap!!!! Looks like an oil cooler is in the bag also.
Old Mar 14, 2014 | 08:24 PM
MisterCMK's Avatar
MisterCMK
^^^what he said
You should look into a fumoto valve. It makes oil changes spotless.
Sent from my mind thanks to the Internet and an app.
Old Mar 14, 2014 | 08:31 PM
9228.bobcat's Avatar
9228.bobcat
Hmm Anthony I wonder who has an oil cooler?? LOL
Old Mar 14, 2014 | 08:38 PM
run6.0run's Avatar
run6.0run
I think I've got about 15 of them stacked up to take to the scrapper!! Lol
Old Mar 14, 2014 | 09:21 PM
9228.bobcat
Yea I have a half dozen junk ones too.lol. need to find me some more deals like that one I got.
Old Mar 14, 2014 | 09:39 PM
jmtbiggin's Avatar
jmtbiggin
Yall slather it on thick.But seriously,delta aside,is the coolant a little cool or is the oil hot.Those numbers came from 5mile drive to supper,3miles at 70 mph on I95 and 2 miles 20-35 mph in town. Oil temp strikes me as normal,but i do not know.
Old Mar 14, 2014 | 09:41 PM
jmtbiggin's Avatar
jmtbiggin
Or perhap my fat finger typed on SG2 wrong?
Old Mar 14, 2014 | 09:45 PM
MisterCMK's Avatar
MisterCMK
A thermostat wouldn't hurt...
Sent from my Telegraph using IB AutoGroup
Old Mar 14, 2014 | 10:23 PM
run6.0run's Avatar
run6.0run
Personally,, I wouldn't recommend a thermostat until a coolant flush and an oil cooler. I see this a bunch. I believe a stuck tstat wil help keep the oil temp lower.
Old Mar 15, 2014 | 08:44 AM
69cj's Avatar
69cj
First check the two temps after the truck sits overnight to make sure the SCll is programmed correctly and the sending units are good. ECT, EOT should be within one or two degrees of each other. Next for the test to be valid you need to drive the truck 15 to 20 miles at highway speeds so that the engine is evenly heat saturated. 60 to 65 mph on level ground. I would also change the t-stat and repeat the test just using water so as not to waste coolant. After meeting all three of these criteria if the deltas are still out of wack then it's cooler time.
Old Mar 15, 2014 | 11:16 AM
jmtbiggin's Avatar
jmtbiggin
Here are temps after 13hrs of sitting
Old Mar 15, 2014 | 11:56 AM
69cj's Avatar
69cj
Now do the other two steps.
BlackBeest
6.7L Power Stroke Diesel
Oct 9, 2013 08:50 AM
2005Dually
Nov 8, 2010 12:03 PM
cobrarep
Aug 5, 2008 09:59 PM
Lnd Svyr
Dec 14, 2004 05:35 PM
croset
Oct 13, 2004 08:55 PM
