VIN Decoder for 1979 F150 ???
Old Mar 20, 2014 | 08:43 AM
  #31
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by Broncoholic1
Hey Mike you see any member picts around here that show what these trucks look like in there original form?
Bronc...
Here's a link that should give you some ideas.
https://www.ford-trucks.com/forums/1...two-tones.html
Old Mar 20, 2014 | 08:52 AM
  #32
mikeo0o0o0's Avatar
mikeo0o0o0
Double post
Old Mar 20, 2014 | 08:54 AM
  #33
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Post 30: Race Track pics from parts catalog. Also notice reference to trans code K (C6).
Old Mar 20, 2014 | 08:56 AM
  #34
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Bill.
Old Mar 20, 2014 | 10:20 AM
  #35
Broncoholic1's Avatar
Broncoholic1
1961/78 F100/350: The IDIOTS at FoMoCo used the Warranty Plate G code for all A/T's.
One had to know what A/T was available with which engine.
But in 1979, the IDIOTS finally woke up.
1979: G = C4 / K = C6.
C6 first offered with 300 & 302 in 1978, but C4 was also offered.
Race Track mouldings: 1977/79 Ranger XLT & 1978/79 Lariat.
1973/76 F100/350 Ranger XLT's came with upper side mouldings w/a black vinyl insert.
The fender/door and cab corner mouldings w/black vinyl insert are the same for Race Tracks.
The Race Track bed mouldings w/black insert are different as they have a curved section at the rear for the vertical mouldings (29396 R/S in pic) to attach to.
Thanks Bill
I have looked all over
Can't seem to find a Lariat
With the KN color scheme.
Light Medium Blue = K
Light Pine Green = N
You ever see this color combo?
Anybody have picts of one?
Or the original codes
3181. H is the pine green
3187 H or 3170 the blue
Have to get proper codes.
Old Mar 20, 2014 | 11:35 AM
  #36
NumberDummy
I have looked all over, can't seem to find a Lariat with the KN color scheme.
Light Medium Blue = K / Light Medium Pine = N
3181. H is the pine green 3187 H or 3170 the blue
What the hell do these codes refer to?
Something smells and it ain't hay.
*BODY code KB4: KB = Blue Vinyl & Blue Cloth (Ranger XLT & Lariat) / 4 = Styleside Pickup.
The COLOR code on the Warranty Plate is KN .. correct?
Blue and green exterior makes no sense, so I would assume that Light Medium Pine is not a shade of green.
*mikeo0o0o0 is using the 1973/79 catalog on a C/D, available from hipoparts.com. It was scanned from the 4/1980 edition, so it has some errors and omissions.
I have this same C/D, but I also have the 10/1988 final edition on microfiche...which is much more accurate.
Old Mar 20, 2014 | 12:15 PM
  #37
Broncoholic1
Yes the color code on warranty plate is KH
Sorry about that. Took a picture of it at night.
So it is KH
Light blue and ? (White)
Old Mar 20, 2014 | 12:25 PM
  #38
Broncoholic1
Trans & Axle code
Here are the Axle codes for the Ranger XLT
Trans = K - C6
Axle = 06J - ???
Edit:
Looks like a 77 up 9"
2.73 ratio open carrier
Power steering front.
Can't find info for it on my
Charts. Not shown for 79?
I have old books. Any updated axle codes.
Thanks again
Getting it sorted out
Bronc...
Old Mar 20, 2014 | 12:28 PM
  #39
NumberDummy
So it is KH
K = Light blue and H = ? (White ).
What color is the truck?
H = DARK BROWN METALLIC / Brown and blue makes no more sense than blue and pine.
But if it's M instead of H then it does make sense, as it's blue and WHITE / M stamped on Warranty Plates may resemble an H
Open your peepers and take a close look at the COLOR code again, or take a pic of the Warranty Plate and post it.
Old Mar 20, 2014 | 12:35 PM
  #40
Broncoholic1
But if it's M instead of H then it does make sense, as it's blue and white.
Looks deformed like a
N. H. M
Guess it is "M"
Light blue and white.
Are there number codes for this or just letter designation?
Sorry about the confusion.
Thanks.
Old Mar 20, 2014 | 01:13 PM
  #41
ford4her's Avatar
ford4her
Question
Is Anything that has the breakdown in warranty plates.
Anything handy
The only "Tag" is on the drivers side inside the door on the body not the door. It is a blue metal tag that says on Line #1 "Replacement Identification Number". Line #2 says "Vin F14HREE4322". Line #3 says "Control No: 420968"
Old Mar 20, 2014 | 01:21 PM
  #42
ford4her's Avatar
ford4her
N. H. M
Guess it is "M"
Thanks.
ect.......
Old Mar 20, 2014 | 02:46 PM
  #43
Broncoholic1
thanks
Originally Posted by ford4her
ect.......
OK back to the show...
Thanks for the cyberspace
Where were you...
Old Mar 20, 2014 | 03:12 PM
  #44
NumberDummy
Looks deformed like a N. H. M / Guess it is "M" / Light blue and white.
What you see on the Warranty Plate for the COLOR code is all there is: KM
For the unaware: Warranty Plate located (riveted) on the left door face below the latch.
Safety Standard Certification Label glued to the B pillar below the striker plate.
Parts catalog lists the part numbers for the touch up paint.
Old Mar 23, 2014 | 11:44 AM
  #45
Broncoholic1
Thanks Bill for the paint codes.
Blue & White she will be back top original.
Found
