Backspacing
Old Mar 13, 2014 | 11:50 PM
Truck Guy99's Avatar
Truck Guy99
Backspacing
What is the stock wheel back spacing for a 1988 F350 4x4 srw? Also, what's the hub diameter? I'm going to order some new wheels for my truck and need this info
Old Mar 14, 2014 | 02:06 PM
mrrish79's Avatar
mrrish79
I think its 4.25" but its been a while since I checked I bought my wheels a few months back.
Old Mar 14, 2014 | 03:19 PM
Conanski's Avatar
Conanski
All Ford wheels for trucks of this vintage have zero offset so the hub surface is dead center of the wheel which were available in 7", 7.5", and 8" widths. HD trucks generally has 7" wheels so backspacing is half that or 3.5".
Old Mar 14, 2014 | 03:46 PM
Truck Guy99
Thanks!
I'm ordering 10" wide wheels, so do I order 3.5" offset?
What is the hub diameter? Most wheels I've shopped for 8 lug trucks are 5 1/4
Old Mar 14, 2014 | 06:21 PM
Bierisch's Avatar
Bierisch
I'm pretty sure it's 6.5" on these trucks, because I believe it was the same as the dodge/chevy pattern until Ford changed to the 170mm metric style.... Right, guys?
EDIT: I'm not even sure if this is what you were asking, but it's here if you need the bolt pattern.
Old Mar 15, 2014 | 04:59 AM
Truck Guy99
No, that's lug pattern. I'm asking about hub diameter (AKA hub bore) I need to know the size of the hole in the middle of the wheel that goes over the hub. I would just check myself but my truck is 200 miles away right now......
M3talGuy
38
Jun 24, 2021 10:41 PM
Highboy727678
Apr 13, 2017 07:59 PM
zukinut
Jan 27, 2013 09:33 PM
djanzen
Aug 11, 2010 09:14 PM
pdtmxqc
Sep 23, 1999 12:11 PM
