mercon VI sync OOPS Dexron VI
Old May 9, 2011 | 09:47 PM
joeyd61's Avatar
joeyd61
I ran up on 4 free quarts of Mercon VI sync trans fluid.....can i use this in the power steering????/
Old May 10, 2011 | 12:54 AM
twags6's Avatar
twags6
To my knowledge, there's no such thing as Mercon VI. Where'd you get it from?
Old May 10, 2011 | 11:04 AM
joeyd61's Avatar
joeyd61
My mistake----its dexron VI full sync......any way is it usable in the power steering?????
Old May 10, 2011 | 11:49 AM
clintbonnie's Avatar
clintbonnie
I would use only mercon or mercon V in the power steering..And if you switch to syn, use only Mobil 1 dexron/mercon, mercon V ATF.
Old May 10, 2011 | 12:40 PM
twags6's Avatar
twags6
No, the system was designed for mercon or mercon V. The reason you dont' see dexron/mercon anymore is because the new fluids (mercon V and dexron VI) have too many differences to make a universal fluid I found an article about this while looking for the mercon VI last night. LUBE REPORT: Ford Pulls the Plug on Mercon
Old May 10, 2011 | 12:49 PM
joeyd61's Avatar
joeyd61
Thanks for the info....I will put it on the shelf for something....
Old May 10, 2011 | 02:15 PM
clintbonnie
You can still buy it.. example: Oreillys.. and Autozone still stock Mercon AFT. Not saying next year.. it might be gone forever..
akblackfoot
Feb 17, 2017 12:47 PM
papadelogan
27831
Oct 22, 2015 05:16 PM
sledhead999
May 31, 2014 06:42 PM
raptor131
Feb 27, 2013 10:00 AM
