1955 Ford F100 Wiring Diagram
for each is also not helpful as the wiring colors are listed different. The wiring diagram I need is in the back of the shop manual... THE COMPLETE SIMPLE WIRING DIAGRAM! THAT SHOWS EVERYTHING! but no,,,, it is simple not to be... Yes, I know,,, go and buy a shop manual... of course I did! it only takes four weeks to get it! due to the total inability for the Vendors... who will remain nameless,,,, unless you really want me to bash them after spending well over a thousand dollars in the last week! But I digress! no where on this forum is there a COMPLETE SIMPLE WIRING DIAGRAM INCLUDING HEATER, WIPER, STARTER BUTTON IS A POSSIBILITY.... Must be made of platinum or a misunderstanding that there is a complete wiring diagram in the back of the shop manual.......................... with the complete info..................wiper motor, heater motor, starter button? not separately,,,, all together..............not the pretty colored useless ones........the complete one...... sorry for the rant........ but thank goodness for the 1st amendment,,, and MOSTLY FOR THE HOT SKINNY CHICK ADVERTISING FOR KOHLS THAT APPEARS RIGHT IN THE MIDDLE OF THE D***NM SCREEN.... I THINK I LIKE THAT THE BEST ALONG WITH ALL THE POPUP ADVERTISING! RIGHT DEAD CENTER IN THE MIDDLE OF THE SCREEN. YOU KNOW.... WHERE WE ALL READ INFO? NOT THAT I PREFER TO LOOK AT ALL THAT WONDERFUL ADVERTISING IN THE MIDDLE OF THE POST! I RATHER ENJOY IT! AS A MATTER OF FACT I THINK I WILL RUN UP AND DOWN THE STAIRS WITH A SHARP PENCIL! OH JOY! MAYBE SOMEHTING WILL CHANGE OR I WILL WASTE SOMEONE ELSES TIME READING MY POST WHO THINKS ADVERTISING IN THE MIDDLE OF POST ARE OK? THE ENTIRE PURPOSE OF BLOGS, FORUMS, ETC... IS FOR SHARING INFO! NOT FOR MAKING MONEY... HOWEVER YOU WILL DISAGREE, LET ME ASK,,, WHY DID YOU BOTHER STARTING THIS IN THE FIRST PLACE? WAS IT TO GET RICH AND TOTALLY DEFEAT THE PURPOSE OF ACTUALLY READING ANYONES POST WITH ADVERTISING COVERING THE POST? SELL OUTS! CLOSE IT DOWN! FIVE ADVERTISING POP UPS IN THE MIDDLE OF POST? REALLY?
As far as the wiring diagram. I don't have my manual in front of me but this one is on Earl's World. It says it's for a flathead engine, but I think it looks just like the one in the manual.
I can double check my manual when I get home this evening.
Johnny - easy there big guy. If you haven't already figured it out, there is some frustration in dealing with old iron: rusty nuts, questionable work by POs, too much time, too little money, hard to find parts, yada, yada, yada. A slightly incomplete wiring diagram -not a problem unique to the 55s by the way - well...
In the diagram above I already see 5 things wrong can anyone see it. I can
fab these harnesses blindfolded in a half hour. Accesories like heaters fans
electric wipers cig. lighters usually are not in prints they were all add on'd from the owner or the dealer shuch as arrow lites.
So whats your pleasure; 1955 6vt pos ground or 12 vt neg ground 6 or v8
dont matter. as far as pop ups etc. I have found google chrome is screwing
around again so I got rid of them & got this foxfire thingy works fine.
I would make a list of what you want, what you want things to do take each
item and start making a harness. One thing you want to do, is a plug connector on the instrument panel about 2 feet. Relocate the circut breaker
on the firewall or kick panel, so in the future if need be disconeck the speedometer cable remove the four screws and work on the panel on your
lap. They must have had insects in the factory to insert instrument
panels in the factory, a terrible thing to get out. Later on like in the 70's
remove panel unplug the harness done that it.
The pop-up advertising is annoying. If you want to get rid of it - join the site for $20 & you get minimal advertising & the ability to post directly from your hard drive. It's probably worth it to reduce your aggravation...
Take a step back & take it easy over there.
Ben in Austin
1950 F1
DW
