6.9 connecting rods
Old Mar 11, 2014 | 11:23 PM
Minime2010's Avatar
Minime2010
Exclamation 6.9 connecting rods
I took apart my engine, and didn't label rods and caps, I've discovered letters on the rods and caps. If can recall correctly there are "D,O,M,C,W,S. The "D and C" are duplicates. I have two rods with "D" and two rods with "C". Do the letters have to match up? And if so what would I do about the duplicates? I'm trying to nat have to take them to the machine shop. Any and all help/advice is greatly appreciated.
Old Mar 12, 2014 | 01:35 AM
IDI guy's Avatar
IDI guy
I would just match them up as best as you can. I am thinking that replacing the conrod bearings will negate the fact that you mixed up the caps if I remember right the caps do have a front and a back but I dont remember how you can tell. I would definitely get new conrod and main bearings and get your crank turned.
Old Mar 12, 2014 | 09:25 PM
Minime2010's Avatar
Minime2010
I took your advice and matched letters, took to machinist and he said that they are all good and not out of round. I greatly appreciate it!
Old Mar 12, 2014 | 11:30 PM
airdale94's Avatar
airdale94
Make sure you check clearances between the rod caps (installed on the crank) and between the rod caps and crank lobe. Not sure the spec. Probably around .002-.003".
Old Mar 12, 2014 | 11:45 PM
IDI guy's Avatar
IDI guy
I will look it up later and post the clearance for you.
Are you an aviator?
Old Mar 13, 2014 | 12:27 AM
airdale94's Avatar
airdale94
Originally Posted by IDI guy
Are you an aviator?
Me? No. Just a brown shoe. I worked the top side on aircraft cariers in the Navy. That's what they (the black shoes - ships crew) called us (airdales).
Old Mar 13, 2014 | 02:31 AM
IDI guy's Avatar
IDI guy
This is for the 7.3l but I'm sure it is the same clearance.
Old Mar 13, 2014 | 09:53 AM
Minime2010's Avatar
Minime2010
I greatly appreciate the guys. Thanks
jbancroft
Dec 28, 2014 02:57 PM
LedheadELH
Nov 8, 2006 07:19 PM
crawlfish
16
May 31, 2005 02:27 AM
Jolbca1962
Apr 22, 2004 11:03 PM
debestuss
Feb 22, 2004 08:04 AM
