random beep/siren
Old Mar 11, 2014 | 08:06 AM
blue924.9's Avatar
blue924.9
random beep/siren
hey all, on my 94 f150 5.0 e4od, i was deep in though the other day while i was starting it, and i paused in between the on and start position, i then got the crap scared out of me when a beep or siren like tone went off, it was like a beeeeep beeeep beeep beeeep and it goes off after 3 or 4 beeps. anybody know what this is, it cant be the headlight door ajar horn because that is unplugged, any help is appreciated, this is confusing the crap out of me
Old Mar 11, 2014 | 09:37 AM
White Max's Avatar
White Max
Has it continued to beep, or did this just occur while holding the key between the "ON" and "START" positions? Does your airbag light illuminate with the other warning lights briefly when turning the key to "ON"?
Old Mar 11, 2014 | 09:52 AM
blue924.9's Avatar
blue924.9
yes, the airbag lights up, the beeping stops as soon as the engine is started even if you start it after the first beep, it wont continue to beep. but it will beep everytime you hold it between the start and run
Old Mar 11, 2014 | 10:01 AM
dixie460's Avatar
dixie460
Only controllers in the truck (stock) that can make noise are the warning chime module and the airbag monitor. Gotta be one or the other.
Airbag module will chime 5 times in 5 groups if the warning light is out, which with the ignition switch halfway between positions it damn well might be not sending power to the cluster yet, but still energizing the airbag monitor.
Let it make noise while you search around for the source... should be pretty obvious where it coming from.
Old Mar 11, 2014 | 10:21 AM
White Max's Avatar
White Max
So it doesn't beep unless holding the key between "RUN" and "START"...why are you holding the key between positions?
Old Mar 11, 2014 | 10:32 AM
blue924.9's Avatar
blue924.9
i was thinking real hard and wasnt paying attention that i had it in between positions when it beeped, scared the crap out of me and i noticed the key was in between the two
Old Mar 11, 2014 | 12:16 PM
White Max's Avatar
White Max
Right, but why are you continuing to do this?
Quit holding it between positions and it won't beep. Problem solved.
Old Mar 11, 2014 | 01:29 PM
blue924.9's Avatar
blue924.9
i only did it twice to see if it did it again, just making sure something wasny messed up or anything
spyder0382
Dec 17, 2014 05:03 PM
abriel68
Nov 5, 2012 08:53 PM
SYKOLINCOLN
1997 - 2003 F150
Jul 29, 2010 06:33 PM
oldschool1965
Escape & Escape Hybrid
Mar 29, 2009 01:06 PM
Bliath
1997 - 2003 F150
Jul 22, 2005 11:37 AM
