F250 c5 axle code. ??????
Old Mar 10, 2014 | 11:12 AM
Anvilman's Avatar
Anvilman
I have a 97 f250 4x4 5-speed. It has c5 axle code. I'm pretty sure the rear is a 10.250 I'm trying to nail down what the front axle is. It has the 10 bolt cover. Any sure fire way to ID it. I read a Dana 50 should have "229" cast into web but I don't c it. There is a num. cast in on the front which is 620093 and A or R. Any help is greatly app
Old Mar 10, 2014 | 04:28 PM
Conanski's Avatar
Conanski
The easy way to know is to simply look at the front hubs, it they're roughly the same size as the opening in the wheel then it a D50, if there is a noticable step down to a smaller diameter it's the D44HD. Also if your truck is over 8500lb GVWR you have the D50 front axle.
And if you haven't decoded your axle code yet.. https://www.ford-trucks.com/article/...de_Chart_.html
Trent Racer
Dec 17, 2018 01:41 PM
macmccrary
Jul 13, 2009 03:58 PM
Trevor1
Jun 17, 2007 07:41 PM
coker0290
Oct 16, 2006 04:36 AM
M998
Mar 18, 2005 09:16 PM
