New fuel pump possibly?
Its a 1984 F250 with a 460 and a 4 speed.
Last night i was driving home from a bond fire at a friends house. The truck was acting fine all day. Put about 75 miles on it earlier with no problems. Well i started the truck up and let it warm up for about 10 minutes (til the choke turned off. Then got in the truck and left. I got about a mile away from her house and the truck started puttering and eventually kieled over. I was in a hill by my school so i was able to coast into the parking lot into a spot.
I tried starting the truck an only got a small sputter then nothing. I got out and noticed i couldnt hear the fuel pump in the front tank. I turned the key on and off a few times and still got nothing. Well it was about 1:30am and i wasnt really in the mood to do anything on the truck so i called my friend and was able to get a ride home in her 2004 3500 cummins.
So after a short nights sleep i headed back out there this morning to see what i could do.
So i started off by pulling the fuel line off the carb and seeing if any came out when cranking the engine. I only got a few drops. Then ichecked all the fuses. None were blown. I heard a while back about the pump shutoff switch under the passenger dash. Well i found it and the white button was popped up. Is it supposed to be up or down inside the unit?
Well i had plans this afternoon so i decides to just tow it home so it i out of the way for school tomorrow.
Sorry for my lack of info. Im very new to electric pumps so I am going off the little bit that i read this morning.
Do you guys have any tips on what i should do now?
Thanks guys!
As with the relay, i read that if it clicks when you turn the key on it is still good. Is that correct? Because i can hear it clicking when turning on an off.
So what sires should i try to jump off the positive terminal? And what should they do?
---> if yours is the same as mine, your fuel pump does not run with the key in run and the motor not running...
The fuel pump receives its power from the starter relay two ways:
1) the bypass circuit energizes the fuel pump only when the starter is engaged. The bypass wire is a 20 gauge fusible link (sometimes hard to come by) that attaches to one of the small posts of your starter relay. The fusible link can burn out and cause this circuit to fail.
As Franklin suggested, you can jump a hot wire from the battery to the bypass terminal and you should then hear the fuel pump run.
Note the other small terminal on the starter relay is the starter signal from your key switch. So it you jump to the wrong small terminal the starter will engage.
2) the normal operating circuit. This is also a fusible link (and possible point of failure). It's a ring terminal attached to the large hot terminal of your starter relay. From there the wire goes to the inertia switch (which should be pushed all the way in BTW) and then on to the fuel pump relay.
You should have power from the starter relay, through the inertia switch, to the fuel pump relay at all times.
But, in order for the power to pass through the fuel pump relay to the fuel pump, the fuel pump relay has to receive the signal from the oil pressure switch.
The oil pressure switch gets its power from the fuse box (blown fuse, possible point of failure) through the key switch (hot in run and start). The oil pressure switch is located on the top of the motor all the back toward the firewall. If you've got an oil pressure gauge there will be a round can with a wire attached to it (the oil gauge sending unit) and at the base of that you will find the oil pressure switch with a couple wires attached.
If you disconnect the wires, with the key ON one of them should be hot. And if you jump the terminals with the key on the fuel pump should run.
In a nut shell:
The fuel pump runs while cranking the starter or when it's running and has oil pressure...assuming everything is working as designed. The fuel pump does not run with the key on but motor not running (unless somebody has jumped the oil pressure switch).
Yikes! I hope that helps.
Oh, and don't forget to check your fuel filter(s).
Next thing I would do is inspect the fusible links at the starter solenoid that supply power to the fuel pump to see if they are still good.
Next thing I would do is jump a hot wire to the fuel pump bypass wire to see if the fuel pump will run that way.
If the fuel pump runs by hot wiring the bypass then I would:
Check for power at the fuel pump relay, hot all the time, coming from the starter solenoid.
Check for power at the oil pressure switch with the key on. If there is no power at the oil pressure switch with the key on the fuse is suspect.
If you have power at the oil pressure switch and have jumped the terminals then you should have power from this circuit at the fuel pump relay with the key on.
If the fuel pump ran when you applied power to the bypass wire, and If you have power at the fuel pump relay from the starter relay hot at all times, and you are getting power to the fuel pump relay via the oil pressure switch circuit by jumping the switch and with the key in run, then the fuel pump relay or fuel pump relay ground is suspect.
Beyond that there might be problems with the dual tanks switches and relays but I don't have any direct experience with those components and have little to offer.
Second. When you say startor relay are you meaning solonoid? The little plastic cylindrical box with the 4 prongs on it next to the battery? I believe thats what youre talking about, just want to make sure. I havent done much looking but from what i can see there are no fuseable wires attached/running from that. Maybe im not looking in the right place.
Third. The fuel pump bypass wire.... Would that be the wire that was put in to bypass the oil preassure switc or no? I have no diagrams or a manual and im use to good ole mec. Pumps.
An hopefully last. Where is the fuel pump relay an ground? If its in the undercarriage then ill need some good direction to find it. The truck may or may not be caked in mud as we speak. Haha.
The rear tank didnt work when i bought the truck so i have never fussed with it. Only turn the pump to the rear tank when the truck will be sitting for a few days to drain all the gas in the carb. Other than that i have always had the seitch to the front tank an this is the only problem ive had.
The PO of this truck could learn something from a monkey when it comes to wireing. The truck has 3 solenoids (only 1 is original), "custom camper plug in" in the bed that is wired beyond terrible, and about 150 feet of stray wire in the engine bay. He had wires running from behind the grille back into the firewall then stops there. He had hot wires running from the battery down the frame to a cap. And alot more. Wireing was not his forte i guess.
Tomorrow ad thursday i do not have work and if the weather is clear i'll have all day to work on the truck.
Thanks for the help guys. Hope to hear from ya soon.
It is probably more correct to say starter solenoid. Follow the positive battery cable from the battery and it should be attached to one of the big lug terminals of your starter solenoid. Also attached to the same big lug as the positive battery cable should be a ring terminal with a length of fusible link, then a splice to regular wire. This is the main power supply for your fuel pump. (In addition there should also be another bundle of larger wires attached to the hot lug of the starter solenoid but you shouldn't have to mess with those).
When I say bypass wire I am NOT referring to the jumper wire you might have jumping the oil pressure switch.
Proceed at your own risk.
The bypass wire I am referring to is a short length of fusible link spliced to regular wire that is attached to one of the small lug terminals of your starter solenoid. This wire bypasses the fuel pump relay system entirely and is wired pretty much directly to your fuel pump. If you apply current to this wire the fuel pump should run and confirm the pump works if it gets power.
A couple words of caution: make sure your truck is NOT IN GEAR if you decide to hot wire the fuel pump bypass. There are two small lugs on the starter solenoid...one is the fuel pump bypass and the other is the start signal wire. If you apply power to the wrong small lug the starter will kick and if the truck is in gear it will jump! DANGER, look out!
The other word of caution is not to try and run the truck using the bypass. That's not a solution. The bypass is only designed to run while the starter is cranking. If you run it that way long term you could burn something up. Especially if somebody has eliminated the protection of the 20 gauge fusible link and is just running the bypass wire directly to the small lug of the starter solenoid.
On mine the fuel pump relay is a smallish square green box with wires plugged into it and I only have one, but yours might have several square green boxes (relays). One for the fuel pump relay and the others as part of your dual thank switch wiring. I've heard of people confusing the relays and changing out the wrong one, or getting the wrong one at the parts store...
Don't forget to check your fuel filters too. Clogged filter = no gas.
Good luck.
