New fuel pump possibly?
Old Mar 12, 2014 | 01:50 PM
ctubutis's Avatar
ctubutis
If it's popped, yes, it should stay down. You might remove the wires from that switch and jump them together and see if that allows the fuel pump to run.
Old Mar 12, 2014 | 02:01 PM
lilsmokey's Avatar
lilsmokey
Yeah it doesnt stay down at all. Ive tried pressint it a bunch of times. Holding it down. Nothing. It imediatley pops right back up. And ive tried jumping the 2 wires but the pump didnt run. So could my shutoff switch be bad too?
Old Mar 12, 2014 | 02:37 PM
ctubutis's Avatar
ctubutis
It's hard to say about your switch as none of us have seen/felt it ourselves. Jumpering the wires eliminates the switch from the equation, so your problems are elsewhere once the switch has been removed from the list of possibilities.
Old Mar 13, 2014 | 02:39 PM
lilsmokey's Avatar
lilsmokey
Ok so dis a little looking this morning.
If it is what i think it is, the oil preassure unit still has the 2 wires attached normally. No splicing or anything.
The only fuseable link from the startor solonoid is a 16 guage and i cant tell where it goes. Goes into a wire wrap that disappears into the trucks bowels.
Lastly is the fuel pump relay the green relay under the hood hinge on the driver side? How can you tell if its good or not?
Dillweed73
Mar 8, 2017 09:12 PM
matthnatow
Aug 9, 2008 09:38 PM
fattmann
Sep 24, 2007 11:44 PM
iwkr40
17
Oct 8, 2006 11:37 PM
Beast12
Electrical Systems/Wiring
Jan 14, 2004 08:09 PM
