Trying to find the cover for the group of stuff next to the battery shown here. It shows the panel folded down. I'm not even sure what this panel is called.
Does anyone know the part number? Looking at FordPartzGiant there is no diagram there to know what I'm looking for.
Ya AUTO Salvage isn't an option.
For the 1997, the actual metal panel the black plastic cover covers up was called the "Engine Compartment Mega-Fuse Junction Panel".
So I guess (at least for 1997) the name for the plastic cover would have been the E-C-M-F-J-P COVER.
I believe 1997 and 1998 shared the same design there, the Mega-Fuses are under the plastic cover, and the starter relay is mounted a few inches to the passenger side of the metal panel, approx. above the A/C accumulator.
Your 2001 doesn't seem to have Mega-Fuses there, and your starter relay is mounted ABOVE the metal panel. So I would assume that a 1997-8 plastic cover would not work on your 2001.
Thanks for the help.
I tried using Engine Compartment Junction Panel since there is no mega fuse but didnt come up with anything. Maybe Shield? ECJP didn't work.
I work at the KCAP and have a 1997 F150 4.6 and found the part name in an old repair manual. Its probably a part you will only be able to get at a junk yard.
Man for the last 13 yrs I have always done my best to keep this area clean never knew there was a cover for it, well I do now thanks to this pic, I will be looking for one too.....thanks alot
