Batt. light/ charging question
Old Mar 8, 2014 | 07:09 PM
minnesota-clint's Avatar
minnesota-clint
If i have a D - C gauge in my cluster now, but a Batt. light wiring harness. Is there any easy way to convert wiring so alternator will charge now untill I can get the resistor, new light and "what not" in order so i can use Batt. light system like I want. Or is it best to carry another charged battery with to swap out.
I just want to drive when needed till i get things in order
Old Mar 8, 2014 | 07:27 PM
ctubutis's Avatar
ctubutis
There are two fairly-heavy gauge wires behind the dash you need to connect together... IIRC they're the green/red-stripe and red/green-stripe, I'm pretty sure they're in the plug that served the original idiot-light cluster. If you follow the traces on the printed-circuit board where those two wires are connected, you'll see they lead to the dash lamp AND they're in fact connected together on the printed circuit via something that kind of looks like a big fuse.
The charging-system wiring is different between the two configurations, you cannot simply replace an idiot-light cluster with a dash cluster without some wiring modifications.
There was a pretty decent discussion on this several years ago, 81-F-150-Explorer explained how it all worked..
Old Mar 8, 2014 | 08:23 PM
minnesota-clint
Trust me, I know there isn't a "easy swap". I just want to drive if possible w/o having to swap batteries all the time untill i get a new/gently used light and resistor, but didnt want to hurt anything in the process
thanx
Old Mar 8, 2014 | 08:49 PM
Franklin2's Avatar
Franklin2
Go out under the hood and find the voltage regulator. If you look closely, you will see the plastic part on the regulator is labeled with letters. One of them should be labeled "I", it will be one on the end with a red/green wire(Or green/red, I can't remember). If you can get 12v to this terminal somehow, it will charge. But you need to take the 12v off this terminal when you park the truck, or it will run the battery down with the engine off.
Old Mar 8, 2014 | 10:28 PM
minnesota-clint
hey franklin2, wouldnt ctubutis"s idea of connecting the red/grn + grn/red together to complete the circuit be a easier temporary fix
Old Mar 9, 2014 | 08:03 AM
Franklin2's Avatar
Franklin2
Whatever you decide. If you are going to take the dash apart to do that, I would go ahead and get a plastic socket light and hook it up between the wires.
Old Mar 12, 2014 | 02:13 PM
minnesota-clint
The wires are wired together, but still no charge.
what is the light for?
I have dash off still, "working out the bugs.
I had the cab gutted because mouse nests in heater core. And am "sorta tryng to care for any/all problems from being "old truckm that sat in pasture for a while.
Old Mar 12, 2014 | 02:39 PM
ctubutis's Avatar
ctubutis
81-f-150-explorer has explained that light's role in the charging circuit and how it works in the past, might search for posts authored by him and see what you can find.
Old Mar 12, 2014 | 02:44 PM
Franklin2's Avatar
Franklin2
You need voltage on the "I" terminal of the regulator to bring the charging system online. It get's it's voltage through the light bulb.
Old Mar 13, 2014 | 11:23 AM
minnesota-clint
and once again I'm just a lil amarter thanx to u fella's.
I appreciate it.
going to do that in case my j.y. trip takes a few more days till i can get there for my short list.
Indybeer
Sep 6, 2015 01:33 PM
GRoper
Feb 7, 2015 09:40 AM
79F150400M
16
Dec 3, 2010 02:25 PM
Elderstarr
Sep 11, 2009 04:14 AM
towing_joe
Jun 1, 2001 07:05 AM
