overheating
Old Mar 8, 2014 | 10:23 AM
calixt0's Avatar
calixt0
overheating
My truck (96 5 liter f150) overheated last night. it looks like the bottom plug on the throttle body blew out. can I drill and tap it? are there replacement plugs? why would it have blown? when I bought the truck i was told it intermittently over heats, this was the first since I've had it. I'm pretty sure the thermostat is working because I can see the temp climb when started and then drop after a short time. I'm not sure if the water pump is working consistently or the thermostat is working consistently or what else might be wrong.
questions
1) why would it intermittently overheat?
2) what would cause those throttle body plugs to blow out?
3) should I just replace the water pump/thermostat/and throttle body? if not what pieces should i leave out.
4) could it be the clutch fan?
I'm not sure what the problem is but I'm wanting this fixed.
Old Mar 8, 2014 | 08:29 PM
Toplait's Avatar
Toplait
A good thermostat does not climb past the temperature specified by the manufacturer. It should climb to operating temperature and the temperature should stay steady at all times....If it pasts the manufacturers operating temperature rating on the gauge and then drops down to operating temperature it is not functioning properly. I have went through many of types of thermostats with problems...The only ones I will use are triple bridged type thermostats. I have had to many problems with the double bridged type thermostats.
IF your water pump is not leaking or making any types of unusual noises then leave it alone. That's just my opinion.
For the throttle body, I don'y know why that happened. You can try fixing it or just get a used one from a junk yard or E-bay.
If your radiator hoses are collapsing on you it will overheat....If they are old I would replace them to prevent collapsing....
If its over heating or the temperature gauge is moving to much on you replace the thermostat with a good triple bridged type thermostat. http://www.oreillyauto.com/site/c/se...150&vi=1122286
I can not answer the question for the fan clutch part.
Old Mar 9, 2014 | 01:07 PM
calixt0's Avatar
calixt0
ok I will get a new thermostat maybe replace the hoses as well. I was talking to a friend who's wrenched a lot on 5.0 mustangs and suggested just bypassing the water in the throttle body by attaching the 2 hoses with a barb. Any one see a problem with that?
Old Mar 9, 2014 | 01:42 PM
timbersteel's Avatar
timbersteel
I bypassed mine as well when I installed my BBK tb.
Old Mar 9, 2014 | 01:58 PM
calixt0's Avatar
calixt0
was also reading on a different forum that the cooling is needed for egr that runs right behind the throttle body. was told a 1/4 " npt tap and plug will fill it
thoughts?
Old Mar 11, 2014 | 02:39 PM
calixt0's Avatar
calixt0
ok fixed the leak in the throttle body and changed the thermostat trying to get this overheating problem fixed. now the truck will idle at normal temps (needle pointing at the r of normal). When I get out and drive the truck it runs hot ( needle on the L of normal) the water is definitely flowing thru the rad as I can see it with the rad cap off. lots of rusty colors and what not...I've flushed it several times already and still getting rusty in the coolant/antifreeze.
Should I just keep flushing.
is it a plugged or partially plugged rad?
I mentioned the fan clutch when up to temp and shut the engine down, the fan makes maybe 2 or 3 revolutions. I know if it keeps spinning its a sign of a bad fan clutch but i'm not sure how much it should spin with a good one.
any suggestions?
Old Mar 30, 2014 | 09:00 PM
calixt0's Avatar
calixt0
ok replaced the radiator and still doing the same thing...
At this point my options are fan clutch or faulty new thermostat... what say you all?
Old Mar 30, 2014 | 09:10 PM
carguy94's Avatar
carguy94
i know i was not asked but did you bleed the cooling system air in the system will cause intermittent over heats. how is the heat in your truck take the tstat out and run the truck if it is the stat sticking then is should quiet the issue. is the fan clutch tough to spin does it spin freely and how is the water pump belt tension it could also be you have a plugged cooling system. and not trying to but in on you alls conversation if i bother you just tell me to bug off. and running the truck with out a thermostat is not a good idea but could give you an idea
Old Mar 30, 2014 | 09:12 PM
eakermeld's Avatar
eakermeld
I would do the fan. I don't think they are supposed to spin ANY after shut down. I might do the thermostat again, too. They are cheap and easy. Just to be safe.
Old Mar 30, 2014 | 10:37 PM
calixt0's Avatar
calixt0
I ran without the thermostat yesterday and ran a flush/cleaner chemical through the system. it took longer to get hot but it just got there and stayed there... I replaced the radiator and flushed the system till clear liquid came out of the bottom radiator hose. then did the same with the heater hoses. when trying to spin the fan when engine cold or hot the fan spins about 1/2 to 3/4 turn just by swinging it. I tried to bleed the system as good as I could but but not sure how to get all the air out short of just running it. I suspected air in the system but couldn't find a way to bleed it?
Old Mar 30, 2014 | 11:17 PM
carguy94's Avatar
carguy94
fords heater core sits high up in the fire wall i would raise the front end just enough to level it turn the temp control to hot and let it run high idle til it comes up to temp might have to burp the hoses and try putting the radiator cap on and off if you have a clutch fan you should then it should spin with resistance like it does and feel the heater hoses one of them should get hot
Old Mar 31, 2014 | 08:00 AM
Daniel5.0's Avatar
Daniel5.0
Loosening the coolant line on the throttle body usually helps with bleeding. It's the highest point in the system.
Old Mar 31, 2014 | 02:27 PM
calixt0's Avatar
calixt0
thanks I'll try that
Totally Tuna
Mar 27, 2018 11:44 AM
cs2kplus
Sep 14, 2016 09:54 AM
timbersteel
Dec 3, 2014 09:18 PM
joe_13894
Sep 10, 2008 11:30 PM
Elendil
Apr 2, 2003 02:51 PM
