compression ratio
Old Jul 1, 2003 | 04:54 PM
redranger90's Avatar
redranger90
compression ratio
Ok guys I hate to ask more dumb questions but I'm still learning engines, and I dont really get this compression ratio, what is it a ratio of? And why do you want to get it lower to add boost to an engine? Thanks for the help.
marti
Old Jul 1, 2003 | 09:07 PM
Rancha9's Avatar
Rancha9
compression ratio
Compression ratio is defined as the ratio between the largest the combustion chamber gets during running (BDC for that cylinder) to the smallest it gets (TDC for that cylinder). In other words, a motor with a CR of 9.5 would have a combustion chamber that is 9.5 times larger at BDC then at TDC. A high CR is typically associated with an engine that is very efficient and "high performance". However, engines with a high CR are more prone to knocking and detonation and are typically referred to as "high-strung". A motor with a turbo or a blower on it must have a lower CR to resist the knocking and detonation that are MUCH easier to cause with forced induction. You CAN have a maotor with a high CR and a turbo/blower, but it would have to be tuned so well that it would cost $$$$$$$. Hope this helps.
Old Jul 2, 2003 | 02:30 PM
redranger90
compression ratio
Thank you! It helps alot, but now I have to ask what TDC and BDC stand for? I'm sure its so obvious I'll hate myself for asking.
thanks again,
marti
Old Jul 2, 2003 | 02:43 PM
Ken00's Avatar
Ken00
compression ratio
Top Dead Center and Bottom Dead Center, when the piston is at the hightest and lowest point in the cylinder.
Old Jul 2, 2003 | 05:05 PM
DainBramage's Avatar
DainBramage
compression ratio
Here ya go http://auto.howstuffworks.com/engine.htm
Study up on that, it'll give you a good foundation, so this stuff at least makes sense..
