6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Rough idle, P0300 Code & pinhole in charge air cooler
Old 04-01-2014, 09:51 AM
shad9876's Avatar
shad9876
shad9876 is offline
Haven't opened them up yet but will need to in order to remove the fuel rail to change the rocker tabs, right?
Old 04-01-2014, 11:26 AM
senix's Avatar
senix
senix is offline
Received 1,524 Likes on 1,087 Posts
I don't think you need to. Try without first.
Old 04-01-2014, 03:29 PM
shad9876's Avatar
shad9876
shad9876 is offline
I was able to remove and reinstall one of the old rocker arm clips, so unless the new ones are significantly stiffer, should be able to get them on without removing the fuel rail or rockers.
Thanks!
Old 04-01-2014, 04:46 PM
senix's Avatar
senix
senix is offline
yeah, most say you can do it with the fuel rail attached.
Few disconnects the better. You will really want to make sure there are no fuel leaks with the new fuel lines.
ZombiePopper
10-01-2014 11:59 AM
shivaskeeper
11-29-2013 11:28 PM
CZFirstFord
07-10-2013 06:06 AM
04fivefour
02-19-2013 07:11 PM
ROBBINthaHOOD
04-26-2011 07:32 AM
Quick Reply: Rough idle, P0300 Code & pinhole in charge air cooler
